Serious question: what do I do? SOLVED!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johntoyota, Jun 19, 2018.
  1. Jun 19, 2018 at 8:23 PM
    #61
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Please don’t drive your truck tomorrow :rofl:
    I hope you’re photographing or videoing your progress for the rest of us.
  2. Jun 19, 2018 at 8:23 PM
    #62
    johntoyota
    johntoyota [OP] "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    I will likely try that before I try drilling anymore.
  3. Jun 19, 2018 at 8:24 PM
    #63
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    I would pull off the entire hub including rotor and wheel, then drill the studs out from the backside. Drilling the studs from rim face side is lunacy
  4. Jun 19, 2018 at 8:25 PM
    #64
    johntoyota
    Down yonder in TN
    16 truck
    I will not be driving it tomorrow. Maybe around the block real slow just to try to get them to work loose a little so I can back them out. Maybe even just a 20' stretch in the driveway to see. No roads. Thank you for your concern though. Youre too kind.
  5. Jun 19, 2018 at 8:25 PM
    #65
    austin2009
    austin2009 Well-Known Member
    Austin
    Boise, Idaho
    Lifted and Locked 09 2.7L 2TR 4x4 5 Speed
    DRIVETRAIN- -4.56 Nitro gears -ARB rear locker -SPC UCA's -Fox 2.5" RR fronts/650lb coils -Bilstein 5100's rear -1.5" AAL -285 BFG KO2’s -16x8 MK6’s ARMOR- -ABR bumper -BAMF LCA skids -Cali Raised sliders RECOVERY- -Smittybilt XRC 9.5k synthetic winch -ARB OBA -Factor 55 Pro Link, Expert STEREO- -Pioneer head unit -Rockford T series speakers -Rockford 500 watt amp -Rockford P2D4 8" sub LIGHTING- -Calirasied ditch lights -Caliraised amber fogs -Hella Black Magic’s -Blue Seas fuse panel
    You won’t be able to do that....can’t get the hub off without getting the axle off. Can’t get the axle off without getting the wheel off.
    05tacomabro likes this.
  6. Jun 19, 2018 at 8:25 PM
    #66
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    pop the wheels and pound out and replace the studs.
  7. Jun 19, 2018 at 8:25 PM
    #67
    johntoyota
    Down yonder in TN
    16 truck
    Its a spacer. Not the lugs on the rotor.
  8. Jun 19, 2018 at 8:26 PM
    #68
    johntoyota
    Down yonder in TN
    16 truck
    Skydvrr and austin2009 like this.
  9. Jun 19, 2018 at 8:26 PM
    #69
    johntoyota
    Down yonder in TN
    16 truck
    If I could get the wheel off, I wouldnt have an issue right now.
    4WALKER, bv8ma, Skydvrr and 2 others like this.
  10. Jun 19, 2018 at 8:27 PM
    #70
    -40
    -40 Well-Known Member
    North Dakota
    01 DC Camburg LT & 17 OR OME BP-51
    1 st Gen TRD Supercharger. URD 7th Inj. Camburg 4x4 LT Kit. Tundra Brakes. 3rd Gen just get’n started, OME BP51 Dakar HD, Camburg UCA & various armor.
    Dremel and a shit load of cutting blades? And a few of the diamond tip drill things not sure the actual name. Kinda grinds and drills at the same time.
  11. Jun 19, 2018 at 8:28 PM
    #71
    johntoyota
    Down yonder in TN
    16 truck
    Definitely going to invest in a good set of bits and spring loaded punch tomorrow. My best punch right now is a screw driver ground to a point.
    Reaper 4x4 likes this.
  12. Jun 19, 2018 at 8:29 PM
    #72
    swissrallyman
    Still I would mark the centers of the spacer lugs and drill them out from the backside. Use a drill bit bigger than the studs and you can still get it done with no damage to the rims... are the nuts on the rear end f!@#ed too?
  13. Jun 19, 2018 at 8:30 PM
    #73
    johntoyota
    Down yonder in TN
    16 truck
    I cant get to the back of them. The back of the spacer lugs are bolted to the rotors which are still attached to the truck.
  14. Jun 19, 2018 at 8:30 PM
    #74
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    this is like a great novel....really interesting....want to read the final chapter:)
    SR-71A likes this.
  15. Jun 19, 2018 at 8:32 PM
    #75
    johntoyota
    Down yonder in TN
    16 truck
    Me too. I can promise you the last line will read, "..... and then he chugged his beer."
    BassAckwards and Spare Parts like this.
  16. Jun 19, 2018 at 8:32 PM
    #76
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    I got nothing except this, 100% relevant I'd say
    4WALKER, remgu2000, Kheiron and 13 others like this.
  17. Jun 19, 2018 at 8:34 PM
    #77
    swissrallyman
    You can if you pull of the hub assembly, drill off the factory lug heads, the pull off the rotor, then drill through the spacer
  18. Jun 19, 2018 at 8:34 PM
    #78
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Idk what the back side of the flange of the hub looks like, but u might be able to grind the head of the stock lug stud off and pound it out the same direction as the lug nut.
  19. Jun 19, 2018 at 8:35 PM
    #79
    johntoyota
    Down yonder in TN
    16 truck
    Thats drilling 12 studs and yanking my whole hub assembly though. Id rather only drill out 5 from the front side and not have to rebuild the knuckle.
    EatSleepTacos and austin2009 like this.
  20. Jun 19, 2018 at 8:37 PM
    #80
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    These are spacer studs. Can't get to the back.
    My only thought is that you gotta split those nuts somehow.
    johntoyota[OP] likes this.
