Serious question: what do I do? SOLVED!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johntoyota, Jun 19, 2018.
  1. Jun 19, 2018 at 8:55 PM
    #101
    tnel12
    tnel12 Well-Known Member
    Oklahoma
    2017 QS TRDOR SB
    icon stage 2, icon rebound, wildpeak at3 285/70/17, rago fab light bar, Cali raised led fogs
    I agree with the socket and hammer method, the only thing I would try before that is if you have a way to heat them before hammering the socket over the lug nut. Just try and give yourself every advantage at this point. Or lots of pb blaster before trying to work them off.
    austin2009 likes this.
  2. Jun 19, 2018 at 8:55 PM
    #102
    johntoyota
    johntoyota [OP] "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Well I cant say that I have been very "entertained" but it is what it is. Ill get it fixed and share my process. Its hard to gain wisdom without royally fucking up here and there.
  3. Jun 19, 2018 at 8:56 PM
    #103
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Another thing that came to mind, which admittedly doesn't make much sense is to drill two holes 180* away from each other and try a pin spanner or even two tiny dowels and spin it off that way.
    johntoyota[OP] likes this.
  4. Jun 19, 2018 at 8:57 PM
    #104
    austin2009
    austin2009 Well-Known Member
    Austin
    Boise, Idaho
    Lifted and Locked 09 2.7L 2TR 4x4 5 Speed
    DRIVETRAIN- -4.56 Nitro gears -ARB rear locker -SPC UCA's -Fox 2.5" RR fronts/650lb coils -Bilstein 5100's rear -1.5" AAL -285 BFG KO2’s -16x8 MK6’s ARMOR- -ABR bumper -BAMF LCA skids -Cali Raised sliders RECOVERY- -Smittybilt XRC 9.5k synthetic winch -ARB OBA -Factor 55 Pro Link, Expert STEREO- -Pioneer head unit -Rockford T series speakers -Rockford 500 watt amp -Rockford P2D4 8" sub LIGHTING- -Calirasied ditch lights -Caliraised amber fogs -Hella Black Magic’s -Blue Seas fuse panel
    This is the last thing I would attempt doing. Carrying a wheel, hub assembly and CV axle into a machine shop and asking them to somehow make it fit on their drill....doesn’t seem too logical man...
  5. Jun 19, 2018 at 8:58 PM
    #105
    johntoyota
    Down yonder in TN
    16 truck
    Youre right. That doesnt make much sense. But cheers for thinking outside the box.
  6. Jun 19, 2018 at 8:58 PM
    #106
    Skydvrr
    Nick
    YMH
    Black '17 OR
    You need the wheel off to pull the axel. You would need an insane machine / custom bit to reach over the length of the axel. Your method doesn't seems to make much practical sense to me.
    austin2009 and johntoyota[OP] like this.
  7. Jun 19, 2018 at 8:59 PM
    #107
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    Don't be hard on yourself, we've all done something that we aren't willing to post on here. I commend you for seeking help! I wish I could be of help but have never faced a situation like this
    remgu2000 and drewhaus like this.
  8. Jun 19, 2018 at 9:00 PM
    #108
    johntoyota
    Down yonder in TN
    16 truck
    Ive faced alot worse on a trail and managed to get off them mountain. At least this happened at my house and I can have the world wide interweb to share my troubles with you fine folks.
    remgu2000 and Lawfarin like this.
  9. Jun 19, 2018 at 9:01 PM
    #109
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    ??? you need a drill press. the axle stays in the truck.
  10. Jun 19, 2018 at 9:01 PM
    #110
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Do you have a large step bit? All you need to do is drill just enough to get the shoulder off. Then the wheel should come off and you won't mess up the inside of the wheel...just a thought:notsure:
  11. Jun 19, 2018 at 9:01 PM
    #111
    austin2009
    Austin
    Boise, Idaho
    No....the axle doesn’t. You’ve got an axle nut on the outer side of the hub.
    DoorDing and Skydvrr like this.
  12. Jun 19, 2018 at 9:02 PM
    #112
    swissrallyman
    yes.. which you remove first..
  13. Jun 19, 2018 at 9:02 PM
    #113
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
  14. Jun 19, 2018 at 9:02 PM
    #114
    johntoyota
    Down yonder in TN
    16 truck
    Thats exaclty my plan of attack tomorrow after I uber it to Lowes and back. Unless anybody in the Littleton area wants to join in on the fun.
    20tacoma17[QUOTED] likes this.
  15. Jun 19, 2018 at 9:03 PM
    #115
    austin2009
    Austin
    Boise, Idaho
    Are you trolling?
  16. Jun 19, 2018 at 9:05 PM
    #116
    johntoyota
    Down yonder in TN
    16 truck
    I appreciate the offer man. I think one trip to the hardware store is going to take care of me. But if we ever meet, Id love to buy you a buy for being awesome.
  17. Jun 19, 2018 at 9:09 PM
    #117
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Had this happened 3 months ago......you know I would have told you "You should've bought a Jeep.....bitch" :rofl:
    The meth head did it.
  18. Jun 19, 2018 at 9:10 PM
    #118
    swissrallyman
    not at all. Just trying to get my point across, of what I would do in the OP's position of getting out of this mess without destroying the rim. In summary:
    -remove center cap on rim
    -remove dust hub cap
    -remove axle nut
    -remove caliper
    -remove hub assembly (4 bolts) with the wheel attached to it
    -bring the wheel-spacer-rotor-hub assembly to machine shop
    -have them drill off the 6 factory lug heads
    -remove rotor
    -drill off the remaining 6 lug heads in the spacer
    that is all. has nothing to do with his axle and can easily be done with a drill press or even hand held drill and avoid damaging the rim.
  19. Jun 19, 2018 at 9:12 PM
    #119
    johntoyota
    Down yonder in TN
    16 truck
    I appreciate the thoughts. I really do. I have done this before on a different truck for different reasons. My memories tell me I dont want to do it to this truck. At worst, I am out $130 bucks for a new rim. I really think I can get the studs drilled out with no damage to the rim. I like that youre thinking and appreciate you sharing your ideas. I am going to go a different route though. Cheers to you too.
    20tacoma17 and austin2009 like this.
  20. Jun 19, 2018 at 9:13 PM
    #120
    austin2009
    Austin
    Boise, Idaho
    I see where you’re going. Most the wheels don’t allow for the dust cover to be removed without the wheel being off, the wheels pinch the dust cover to the hub.
