Serious question: what do I do? SOLVED!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johntoyota, Jun 19, 2018.
  1. Jun 19, 2018 at 9:27 PM
    #141
    johntoyota
    johntoyota [OP] "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    ^^^^^^ what he said
    And dont forget, ubering it back.
    austin2009 likes this.
  2. Jun 19, 2018 at 9:30 PM
    #142
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    LOL the Uber... feels good to laugh again. at the end of the day its the OPs call what route to take, best of luck to him and after 8 pages of discussion he definitely owes us some progress and after pics. Send it!
  3. Jun 19, 2018 at 9:31 PM
    #143
    johntoyota
    Down yonder in TN
    16 truck
    I usually dont think about taking pictures while I do shit, but Ill do my best this time.
    EatSleepTacos likes this.
  4. Jun 19, 2018 at 9:37 PM
    #144
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Good on ya for having a good outlooy. No matter what it's guna get fixed and fixed right. Only variable is cost. Don't panic, you'll get it.
    swissrallyman likes this.
  5. Jun 19, 2018 at 10:02 PM
    #145
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    The wheel studs should be 12mm(.472) so get a bunch of 29/64 (.453) or maybe 7/16(.437) drill bits. Center punch the lugs as close to on center as possible and drill away, should only have to drill to the bottom of the taper of the nut and they will probably pop off. Good luck OP, it's gonna be a bitch. BTW, I'm a machinist and this is how I would do it.
  6. Jun 20, 2018 at 3:46 AM
    #146
    Clearwater Bill
    Billy
    Largo Florida
    If you roll the truck on it's side, it will let cooling lubricant (ATF is a good one, way better than WD40) puddle around the area. And you'll be able to drill in a vertical position. Much easier than drilling horizontally.
    But seriously. Good luck with the project, and keep us posted.
    DoorDing, dskakie, 06trdtaco and 5 others like this.
  7. Jun 20, 2018 at 4:08 AM
    #147
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
  8. Jun 20, 2018 at 4:30 AM
    #148
    TacoWil
    TacoWil Well-Known Member
    2018 Blue Tacoma TRD Pro
    I use impact but I use a Torque Stick to install, works well.
    johntoyota[OP] likes this.
  9. Jun 20, 2018 at 6:38 AM
    #149
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    I'm interested in how this turns out. Hope you can save the rim.
  10. Jun 20, 2018 at 6:43 AM
    #150
    johntoyota
    Down yonder in TN
    16 truck
    Thank you. Wtih Chuck rooting me on, I cant lose.
    I think my rim is going to be ok. It may get a knick or two but if I have to I can make it a spare. Even if I booger the inside of the hole a little bit, the cone part should stay in good shape. And if 1 out of 6 has a slight knick inside, I think Ill be ok.
    Ill definitely let everybody know how it goes.
    Lawfarin and TexasTacoLT[QUOTED] like this.
  11. Jun 20, 2018 at 6:50 AM
    #151
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    They do make a tool/socket for removing locking lugs without the key. Should work for your need. It has teeth that grabs out side of lug. Most auto parts/body shops stores have them. Google it.
    la0d0g likes this.
  12. Jun 20, 2018 at 6:55 AM
    #152
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Whatever you finally get to work...plan on doing with the other three wheels.
  13. Jun 20, 2018 at 6:55 AM
    #153
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    If I understand correctly, you have the shoulder of the lug nut still clamping the wheel to the hub/brake. And there is the exposed stud sticking out now. Am I right?
    I would look at getting a bimetal hole saw that will just fit around the stud to center it and just carefully chew away at the remaining lug until you are just about to touch the rim. You should be able to pick out the final bit of nut shoulder without damaging the lug surface on the rim.
    Put some Gorrila tape around the outside of the hole saw just above the teeth to act as a rim protector as the hole saw turns.
    SR-71A likes this.
  14. Jun 20, 2018 at 6:57 AM
    #154
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    :popcorn:
    Joe23 likes this.
  15. Jun 20, 2018 at 7:02 AM
    #155
    johntoyota
    Down yonder in TN
    16 truck
    If I had any of the nut exposed, I would go this way. It snapped off at the shoulder.
    Without a doubt. I hate knowing that I have 18 more of these on the truck that were installed the same way.
    Definitely investing in a good set of bits and a torque wrench today.
  16. Jun 20, 2018 at 7:03 AM
    #156
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Spline drive isn't supposed to be installed by impact.
  17. Jun 20, 2018 at 7:07 AM
    #157
    Joe23
    Drill a small spot on the lug remaining and hammer it till it breaks off? Dunno
    @Ttaco15 how did you get yours off when it broke
  18. Jun 20, 2018 at 7:12 AM
    #158
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    This is a bi-metal hole saw.
    Get one that will fit over the remaining stud, yet still fit inside the rim hole.
    Do not use a pilot drill, just use the hole saw over the stud to cut away at the rest of the lug nut.
  19. Jun 20, 2018 at 7:17 AM
    #159
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    Too many ugga duggas
    MESO, Lawfarin, TacoJova and 2 others like this.
  20. Jun 20, 2018 at 7:23 AM
    #160
    johntoyota
    Down yonder in TN
    16 truck
    Hindsight.
    Ive never had spline drive either.
    Joe23[QUOTED] likes this.
