Serious Wheel Question
Discussion in 'Wheels & Tires' started by rsincavage85, Apr 19, 2011.
  1. Apr 19, 2011 at 6:46 PM
    rsincavage85
    rsincavage85 [OP] Well-Known Member
    Rick
    Plains Twp. Pa.
    Super White SR5
    I know use the search function and I did. I am looking to get new wheels mine are OEM and they are shot. Good for winter. I am looking to buy black wheels with maybe some machined edges, I think they look good like that. What I am confussed about is backspacing and offset. Can anyone help me out. I have about 2" lift up front and rear is little less than 2" almost sits level. I want to stay with the 1" wheels. just not sure about the backspacing and things. I am figuring 4.5 for the backspacing. Would that be good incase i wanted to go to a 265/75-16 i am running with 265/70-16 currently? And maybe some one saw thie thread with someone haveing I think an ATX wheel with Dyno pro atm's. I have the tires and like them alot, they looked good with the wheels this person had. Just didn't even pay attention to the subject now I can't find it.
    Thanks
  2. Apr 19, 2011 at 11:18 PM
    JdMeF9SiR2
    JdMeF9SiR2 PARTS HOARDER
    Riverside CA
    06 Tacoma
    you want to run 16x8 with a 4.5 backspacing
  3. Apr 20, 2011 at 6:18 AM
    rsincavage85
    Rick
    Plains Twp. Pa.
    Super White SR5
    Thank you! I see it can be + or - which would it be this where I keep getting confused. I see I did forget to put the size wheel which would be the 16x8.
  4. Apr 20, 2011 at 12:57 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    0mm offset
  5. Apr 20, 2011 at 6:06 PM
    rsincavage85
    Rick
    Plains Twp. Pa.
    Super White SR5
    I was looking around on line and saw some one had 5" backspacing what would that do, push the wheels out from the truck further for a wider stance?
  6. Apr 20, 2011 at 6:11 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    That would push the wheels in .5" in comparison to a wheel with 4.5" backspacing. IMO stay with 4"-4.5" of backspacing
  7. Apr 21, 2011 at 10:55 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    If you are only looking to fit 265s, anything between 4.5-5.5" backspacing will be fine
  8. May 3, 2011 at 4:12 PM
    rsincavage85
    Rick
    Plains Twp. Pa.
    Super White SR5
    Ok thanks, I don't completely understand what the offset does. Thanks for the information.
  9. May 3, 2011 at 7:56 PM
    KPT
    09 Prerunner
