Serp belt or other issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dagralph, Jan 8, 2023.
  1. Jan 8, 2023 at 4:21 PM
    Dagralph
    Dagralph [OP] Well-Known Member
    2015 SW DCLB taco
    Need help diagnosing sound. Pretty sure it’s serp, stealership wants me to leave it with them for the night to diagnose. I’d rather just know and then try to fix it myself.
    Tried to upload a video but it wouldn’t work. Squeal comes when I start the truck and gets better as I drive. Used to just go away, but now it’s being a bit more stubborn.
    https://youtu.be/fhHpNYp7bjI
    Lmk what y’all think.
    thanks everyone
  2. Jan 8, 2023 at 4:25 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    To post a video you have to post it to a video sharing site like youtube and then post the link to it here.
    Dagralph[OP] likes this.
  3. Jan 8, 2023 at 4:29 PM
    Clearwater Bill
    Billy
    Largo Florida
    Belt isn't expensive is it?
    Mileage justify a change? If so try it and see what happens.
    While off, check all the pulleys
    Superdave1.0 likes this.
  4. Jan 8, 2023 at 4:47 PM
    Dagralph
    2015 SW DCLB taco
    Alright videos up.
    probably justifies. Almost 100000 miles now. I wouldn’t be able to do it myself so I’d need help or pay someone or take it in.
  5. Jan 8, 2023 at 4:52 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Take the belt off and see if the noise goes away
    Geeves77 and wi_taco like this.
  6. Jan 8, 2023 at 4:53 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Not too difficult a job, there are other step by step videos out there. In case you want to save some money and give it a go.
    https://m.youtube.com/watch?v=KG3qwjiCWQE
    Dagralph[QUOTED][OP] likes this.
  7. Jan 8, 2023 at 4:54 PM
    Bishop84
    Bishop84 Well-Known Member
    Can't hear anything worthwhile, but I agree with the idea "It's due anyway just do it"
    Your truck sees a lot of road grime/mud, belts don't like that, plus it looks like one rib is worn.
  8. Jan 8, 2023 at 5:05 PM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    If you replace it make sure it’s completely on all the pulleys correctly.
    A member did his and do to it not being on the crank pulley correctly the belt came off
    And took out his front main seal on the first start up. Definitely double check it before starting it up.
  9. Jan 8, 2023 at 5:26 PM
    Dagralph
    2015 SW DCLB taco
    Good to know. Y’all think I should just do the belt or the pulleys too?
    That does make it look pretty easy. With my luck I’ll end up blowing the tranny when I do it lol ;).
    10thMTNgrunt[QUOTED] likes this.
  10. Jan 8, 2023 at 5:29 PM
    Bishop84
    Thats a 2.7, the 4.0 is done from underneath typically.
    Start with the belt. (my opinion)
  11. Jan 8, 2023 at 5:56 PM
    10thMTNgrunt
    2013 TRD Sport
    Give yourself some credit, and we’re always here to help mid job if problems arise.:thumbsup:
    Soul Surfer likes this.
  12. Jan 8, 2023 at 6:03 PM
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
    Spray the belt with spray bottle of water on stream. If it changes then it’s the belt.
  13. Jan 8, 2023 at 8:20 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    At 100k you on a belt, you need to do it anyways. Pull the old belt off, store it in the truck just in case.
    While you have the belt off spin everything by hand especially the idler and tensioner pulleys
  14. Jan 8, 2023 at 8:36 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    To elaborate on the water test, spray some water on the inside of the belt, if the noise goes away momentarily, the belt is likely the culprit although that does not rule out a faulty tensioner which can cause belt noise if there is not sufficient tension. If there is no change in noise with water, then a faulty bearing is likely the cause - but which bearing?! With the belt off, rotate each bearing to feel for smooth free spin and no side to side or fore/aft movement. Before removing the belt you can try the following.
    https://youtu.be/fHtLH_m9gN4
    Z7Xtreme likes this.
