Serpentine belt again
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12retire, Jul 23, 2022.
  1. Jul 23, 2022 at 11:23 AM
    12retire
    12retire [OP] •••••••••••••
    So Cal
    2014 TRD Off Road. Pyrite Mica
    I read a post about serpentine belts but cant find it now. Apparently Toyota does not sell there belts or I cant find them. What aftermarket belt is the best?
  2. Jul 23, 2022 at 11:28 AM
    Mallrat60
    Mallrat60 Not all of us in CA are libs.
    Nor-Cal, Sacramento area
    2015 Dbl cab L/B 4X4
    ADS 2.5 #700 springs, RCI metal fab full skids, JBS UCA, OME rear leaves, Fab Fours front, and rear bumpers, BAMF Rock Sliders and other stuff
  3. Jul 23, 2022 at 11:37 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Bando is the OEM manufacturer for Toyota tacoma serpentine belts. They use the same part number for the OEM and the aftermarket version they sell outside of the stealership. You can find it on rockauto and it is cheaper to get it outside the stealership.
    NobDriver and Rob MacRuger like this.
  4. Jul 23, 2022 at 11:46 AM
    12retire
    So Cal
    They do have it. 47.00
    I was checking dealerships and they dont carry.
  5. Jul 23, 2022 at 11:49 AM
    12retire
    So Cal
    13. Bucks at rock auto. What a huge price difference
    NobDriver, GilbertOz and Alexely999 like this.
  6. Jul 23, 2022 at 12:00 PM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    I buy the Bando made in Japan, about $20 delivered.
    SR-71A, HandOfGod and Alexely999 like this.
  7. Jul 23, 2022 at 12:18 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
  8. Jul 23, 2022 at 12:28 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Strange... i just got a oem one at my dealership a hour ago. Double checked the part number when i got home and of coarse they gave me the 90916-A2037 (2015-2022.). For my 2007 should be 90916-A2001 (2005-2015.) They must of just got the belt in... has a date of 7/18/22 on the packaging. Called the parts dept... they have the 90916-A2001 in stock also.
    SR-71A and 10thMTNgrunt like this.
  9. Jul 23, 2022 at 12:41 PM
    10thMTNgrunt
    2013 TRD Sport
    That’s good to hear!
  10. Jul 23, 2022 at 1:44 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Bando
    Rob MacRuger likes this.
  11. Jul 23, 2022 at 1:50 PM
    OffroadToy
    Yeah.. my dealership has the Bando's in stock now... said for a while they were having trouble getting them from the manufacturer.
  12. Jul 23, 2022 at 2:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I replaced my original belt with another Bando thinking they were the same, they were not. The new one squeaked when cold right out of the box.
    Put a Gates belt on and no more noise
    acparker12 likes this.
  13. Jul 23, 2022 at 2:55 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I used the Gates also. So far so good.
    Been on 3 years now.
  14. Jul 29, 2022 at 12:01 PM
    Rob MacRuger
    2006 4X4 SR5 4.0
    I had just the opposite problem, I bought Gates because I bought the entire Gates tensioner and idler kit. The belt sucked and was replaced ASAP, skinnier than OEM and made noise. I only look for Bando with Japan markings since.
    OffroadToy likes this.
  15. Jan 17, 2023 at 5:55 PM
    ecenter
    ecenter Active Member
    Eddie
    2019 Tacoma L4
    Replaced my tensioner and Serpentine. Aftermarket belt, already making intermittent loud noise on first start in morning. Is the OEM belt really that much better, or maybe sized better? I’m gonna get one, just wanted your opinions. Thanks!
  16. Jan 17, 2023 at 6:25 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    I don’t know if it’s “that” much better than x other but I can say oem was my only consideration when I changed mine. I still had the original oem belt on and it was in excellent shape and not making any noise. Changed it out due to age. It is now a spare behind my seat. New belt hasn’t made a peep either.
    Edit: FYI I bought my oem belt from the dealer in august 2022. Not sure why people are having a hard time finding them. My dealer had lots in stock.
  17. Jan 29, 2023 at 7:37 PM
    Stevevader
    Stevevader Member
    2019 TRD Off Road 2WD
    Replaced my Serpentine with a Gates today (first time)...Procedure was just as our great forum posters have typed up.
    But, man the toughest part I believe was just getting into a stable position from top of engine.
    I did remove skid plate, but I really felt I couldn't get leverage for releasing tension on belt from underneath truck.
    Will it get easier or should I build some Engine Bay Scaffolding for these jobs?
    Oh Yeah, I have a quiet Taco again!
    :muscleflexing:
