Serpentine belt change... results
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alquimista, Feb 1, 2024.
  1. Feb 1, 2024 at 12:45 PM
    Alquimista
    Alquimista [OP] Well-Known Member
    México
    2012 TRD Sport 4x4 Double Cab
    Hi,
    I bought my Tacoma v6 4x4 2012 back in 2015 with around 80,000 kms on it; now I have near 170,000 kms, and as far as I recall the serpentine belt had never been changed; don't now if the previous owner had it changed. I took the truck to a local Toyota dealership to have it replaced... The old belt had a brownish color, was dry with a few cracks on the rubber guides. Driving with the new belt, I felt the motor more responsive, indeed better. What would be the logic behind this better power response?
    Regards
  2. Feb 1, 2024 at 12:55 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Better alternator traction :notsure:
  3. Feb 1, 2024 at 2:02 PM
    TacoTuesday1
    SD CA
    maybe they did a diagnostic scan while it was in there that usually automatically clears when exiting and reset everything
  4. Feb 1, 2024 at 2:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I can’t think of any reason it would run better by changing the belt:confused:
    HondaGM and SR-71A like this.
  5. Feb 1, 2024 at 4:10 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’ve found hitting the erase codes function with the scan tool does the same as disconnecting the battery, except the clock & radio don’t need to be reset after.
    HondaGM likes this.
  6. Feb 1, 2024 at 4:19 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    placebo effect
  7. Feb 1, 2024 at 4:25 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    This is how I feel after doing my Big 7 upgrade. I'm sure it's just placebo.
    HondaGM likes this.
  8. Feb 1, 2024 at 4:28 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Placebo. Nonetheless good you got it done. Dont want to be left with a broken belt
    HondaGM likes this.
  9. Feb 1, 2024 at 4:31 PM
    tcjacado
    tcjacado Well-Known Member
    Either carry an extra belt or a pair of panty hose:cool: and tools to fix it. Otherwise, get AAA and tow it.
    HondaGM likes this.
  10. Feb 1, 2024 at 4:33 PM
    SR-71A
    Zack
    Southern Maine
    Do I wanna know? :confused:
  11. Feb 1, 2024 at 4:37 PM
    Alquimista
    México
    I don't think they erased codes, nor did any ECU / battery reset; I have the ECU re-flashed for better performance, and the re-programming is still there.
    HondaGM likes this.
  12. Feb 1, 2024 at 4:38 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    I think it’s so you can hitch a ride:rofl:
    tacoman45, HondaGM and tcjacado like this.
  13. Feb 1, 2024 at 4:40 PM
    tcjacado
    It's an old school trick. ;)
    HondaGM likes this.
  14. Feb 1, 2024 at 4:42 PM
    SR-71A
    Zack
    Southern Maine
    :rofl::rofl:
  15. Feb 1, 2024 at 4:44 PM
    SomeGuy_GRM
    IYKYK
    HondaGM likes this.
  16. Feb 1, 2024 at 4:49 PM
    tcjacado
    :notsure:
    HondaGM likes this.
  17. Feb 1, 2024 at 7:15 PM
    Alquimista
    México
    I searched a bit on the web on bad serpentine belt symptoms... As per this site
    6. Power Loss
    If the serpentine belt is damaged or broken, it can cause a loss of power. A serpentine belt is responsible for driving several engine components, including the alternator, power steering pump, and water pump.
    If the belt is worn or damaged, it can cause these components to work less efficiently, resulting in poor engine performance
    So, makes sense what I perceived.
    Thank you all, for your comments!
    HondaGM likes this.
  18. Feb 1, 2024 at 7:24 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It would have to be slipping (and squealing) to affect alternator/water pump/power steering performance. And that would be the fault of a weak tensioner
    HondaGM likes this.
  19. Feb 1, 2024 at 8:53 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    Bad data here. A slipping belt would impact the performance of those components listed, but none of them are considered the engine and will not impact engine performance. An exception is the water pump, but unless temps rose above the target, no engine performance is lost.
