Serpentine Belt Keeps Going Bad on '15
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Koplinsky, Jan 1, 2021.
  1. Jan 1, 2021 at 1:03 PM
    Koplinsky
    Koplinsky [OP] Member
    Pennsylvania
    2015 Red Taco
    Hey gang,
    So my 2015 just got its third serpentine belt since I've owned it - bought it with 36k miles in 2017, just eclipsed 100k last month. What on earth could it be? The dealership looked into it, says everything checks out - I continue to go to the dealership because I bought the extended warranty for the truck.
    I DO NOT off road, if that even matters. 70% of the mileage is highway. The truck is manual. I don't drive like a knucklehead, these trucks are expensive I do not have the disposable cash to beat on it and fix it.
    I think my next move is to take it somewhere else and have them look at the pulleys, that is only thing I can think of that would eat serp belts.
    Any and all insight is greatly appreciated.
  2. Jan 1, 2021 at 1:05 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Sure would help if you told us exactly how it is going bad.
    Soylent Green2012 likes this.
  3. Jan 1, 2021 at 1:13 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Pulley alignment/bearings, foreign substances (coolant, oil, etc...), and improper installation are about all that will destroy a belt. As Fullboogie said it would help to know how it was failing.
    6 gearT444E likes this.
  4. Jan 1, 2021 at 1:15 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    That sounds too high, agreed. I just replaced mine at 112-113K on my 2010 last fall. The belt probably could have been still used, but with the age, getting a new one for basically free, and the cold weather season being here I felt it best to just do it for peace of mind.
    That said, I would agree with your statement that the pulleys should be checked as well as the tensioner. If one pulley is acting up just replace them all is my advice to you. Pretty sure you can find the set for 100-150 or so online if I remember right.
  5. Jan 1, 2021 at 1:18 PM
    Koplinsky
    Pennsylvania
    2015 Red Taco
    I was told it had a large "crack".
  6. Jan 1, 2021 at 1:27 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's very vague, I would want to ask for the old parts and see for myself what it looked like.
  7. Jan 1, 2021 at 2:02 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    You're going have to actually open the hood and look at the belt or this is pointless..
  8. Jan 1, 2021 at 2:07 PM
    Koplinsky
    Pennsylvania
    2015 Red Taco
    If I didn't need help figuring this out I wouldn't have posted on the forum. Not everyone has experience with motors.
  9. Jan 1, 2021 at 2:07 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    look at the part yourself. dealerships are rarely trustworthy.
    Lester Lugnut likes this.
  10. Jan 1, 2021 at 2:13 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Take some pictures of the belt and drive pulleys and post them otherwise I'm afraid we won't be able to help you much.
  11. Jan 1, 2021 at 2:15 PM
    rustyfromskowhegan
    rustyfromskowhegan Well-Known Member
    2013 AC 4x4
    Wondering what is leading you to replace the belt? Is it due to failure? Noise? Or mechanic/dealer advice? OEM belt or an aftermarket brand? If good belts are being put on to start with then it has to be something it’s spinning on or external debris/contaminants causing issues. Have you noticed any squeaking or chirping? Any issues with any drive belt components that might impact the belt (alt, ac, water pump)?
    XSplicer62 likes this.
  12. Jan 1, 2021 at 2:38 PM
    fixnfly
    S.W.PA
    I get what you are saying but sometimes YOU need to put some effort into finding a solution to the problem.
    Fuck it.
    Good luck buying belts.
    6Thick, Fullboogie and ucdbiendog like this.
  13. Jan 1, 2021 at 2:38 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    Or installing the wrong belt, admittedly a long shot. Very doubtful the dealership would install an incorrect belt three times.... but you never know.
  14. Jan 1, 2021 at 2:58 PM
    Soylent Green2012
    Soylent Green2012 RestoRides MotorSports
    jake
    Apopka, Florida
    2012 Tacoma Pre runner SR5 V6 Limited Edition
    chrome bull bar, 20" vision wheels, LED lighting, Custom grill.
    The above comments are an indication of what could be wrong. Not being able to see even
    images is somewhat of a crap shoot to say for sure what is the problem.
    Do you have any of the belts they took off ?
    If so look at the ribs and the flat side for damage.
    The tensioner itself may be damaged.
    Again as mentioned any squeal or scrubbing sounds when engine is running in neutral / hood open?
    It is possible one of the pulleys is cracked or damaged.
    If an idler pulley has a bad bearing it MAY not make any noise
    but would be prone to get really hot.
    3 belts in short order means something is wrong- Have it inspected up close.
  15. Jan 1, 2021 at 4:00 PM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Best advice I can up with is take it to another mechanic and a second opinion. At the very least. All we can do is guess at this point.
  16. Jan 1, 2021 at 4:08 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Ask them to show you the "crack" next time. A couple cracks here and there on individual ribs is not a big deal. A big crack that goes through multiple ribs in the same place is reason to replace.
    jackn7 likes this.
  17. Jan 1, 2021 at 5:48 PM
    ABA180
    East Bridgewater MA
    Not a bad idea, but if you're already replaced the belt recently it can't hurt to at least check the pulleys.
    jackn7[QUOTED] likes this.
  18. Jan 1, 2021 at 6:58 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    O.P. if your belt was installed correctly,then 1 or more of your pulleys is bad/bent,you will have too take the belt off and check all the pulleys for smooth operation,its not a hard job at all.
  19. Jan 1, 2021 at 9:25 PM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    Gotta agree with this. Without pictures of the failed belts, while all solid advice, the posts above are literally throwing darts in the dark while blindfolded. The dealer could just be taking you (OP) for a ride for normal cracking on a serp belt.
  20. Jan 1, 2021 at 9:48 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Is the belt failing and leaving you sitting, or are you just being told that the belt is bad by the dealer service writer when you’re in for an oil change ?
    Belts do have a decently long lifespan, changing them prior to actually failing is preferred, as sitting on the roadside isn’t fun, or ideal.
    If you’re being told this when in for periodic maintenance then you’re being “upsold” by the service writer, they make $$$ on anything they can push. The tech also makes money on any other service or parts he can “up sell” you may not actually “need” it as bad as they are is where being informed and aware comes in.
    A lot of folks don’t even know how to open the hood, let alone know the different components.
    Keep a mileage ledger for repairs in your phone or laptop, tracking mileage and repairs and suggested repairs. Replacing a belt every 20k is over kill, 50-75k is reasonable, but still not really normal. 80-100k I’d let it happen. This is replacement mileage from its LAST replacement, not actual odometer miles.
    Dealerships tend to be overly dramatic to make the sale, I just had my work van in for a broken oil fill pipe (it’s been broken for several weeks, but I just saw it yesterday) They recommended it staying there and not driving it because oil “might” spill out and cause a fire...... the reason I even looked was I could smell oil, when I looked I found the broken fill pipe at a support bracket, but there was no oil mess anywhere....(BTW I AM a mechanic by trade, the ONLY reason this was at the dealer was because van is still under 3/36 warranty, otherwise I would do the repair myself.) I also used to work for the dealer I took it too, but it’s been long enough most everyone I knew or worked with has moved on, I know the game. It hasn’t changed since I was there.
