SERPENTINE BELT OR PULLEY ISSUE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jfuent268, Sep 20, 2013.
  1. Sep 20, 2013 at 1:46 PM
    jfuent268
    jfuent268 [OP] Member
    Yuma, AZ
    07 SR5 4x4
    So recently when i turn on my truck it squeaks/squeals for a couple of seconds, but only when the engine is cold or the weather is cooler. I have never replaced the serpentine belt on this truck. Does anyone have a clue if it is the serpentine belt or possibly which pulley it could be.
    its a 2006 Tacoma base model with 4x4
    any help ! thanks
  2. Sep 20, 2013 at 2:14 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Likely the pulleys, I did this recently myself.
    Pulley 36173 replace I/D 1 and 2
    Pulley 36174 replace I/D 3 and A/T
    See here for part numbers:
    http://www.toyota120.com/forum/showthread.php?t=4047
    edit: you can pull them all and find out which one is bad, or just swap them all, but they are kind of expensive.
    edit#2: I am 90% sure they are they same as on the Taco.
  3. Sep 20, 2013 at 3:06 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    I would put a new belt on it first.
    It is a easy install and will let you know for sure if the belt is a issue or not. It is part of maintenance to replace anyways a pulley is not.
    Another item that could be failing is the belt tensioner. If it is not strong enough even a new belt will not last long and start glazing over due to a weak tensioner.
  4. Sep 20, 2013 at 3:07 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    belt then the top dead center idler pulley are the normal culprits in order of likely hood and price...
  5. Sep 20, 2013 at 3:13 PM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    X2 on belt replacement. Age and miles will make the rubber hard. Start up with cold fluids and parts plus the alternator working hard to recharge the battery puts a lot of strain on the belt.
  6. Sep 20, 2013 at 3:19 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    An old trick from back in the day is to pour some water on the belt as the car is running. If it quiets down, it's the belt, if it still squeals its a pulley. Obviously do this with only a cup of water and don't get close to the belt.
  7. Sep 21, 2013 at 7:15 PM
    jfuent268
    Yuma, AZ
    07 SR5 4x4
    thanks guys
    I have replaced the belt for now
    hopefully that was the issue
    if not I will have to start looking at the tensioner and pulleys
    once again, much appreciate the info
  8. Sep 21, 2013 at 7:23 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    mine did the same. It wasthe belt. It would squeal for about 5-10 minutes until it warmed up. Replaced it and problem solved. The belt is $$, being for how damn long it is lol
  9. Sep 21, 2013 at 7:23 PM
    pinktaco808
    pinktaco808 Hot Steppa
    easy to change? hot to change the serpentine belt?
  10. Sep 21, 2013 at 7:26 PM
    snowgod06
    Rob
    06 Access Cab
    easy with the right socket and long handle ratchet. Having an extra person to help is nice. PAY attention to how its routed tho!
  11. Sep 22, 2013 at 1:11 PM
    jfuent268
    Yuma, AZ
    07 SR5 4x4
    agreed with snowgod
    it was the first time I did it on my truck and it took me 20 min. 14mm socket / long wrench
    an additional person to prevent the belt from slipping out while you route the belt
    mine hasn't sqeaked or squealed so far
  12. Sep 22, 2013 at 1:45 PM
    Smtaco89
    Smtaco89 Well-Known Member
    Shane
    South Texas
    06 SuperWhite 4x4 Sport SB
    AFE CAI, Magnaflow Off-Road Pro Series Cat-Back with Ultra quiet resonator, ImMrYo Mirror Lift Bracket, Dipped Stock Rims & Front Bumper Valance, Weathertech Digital Floormats, Tinted, Fog Lights Anytime, Tailgait Theft Deterrent, Valentine One Radar Detector, Jumpers LED's
    The first time I changed my serpentine belt I didn't have a long breaker bar and was low on cash so I found myself in a bit of a bind. Eventually I figured out that if you remove the skid and come up from the bottom it's not to difficult for someone with the wrong tools and a lot of patience to replace the belt.
  13. Sep 22, 2013 at 9:38 PM
    pinktaco808
    is this guy right or what thought it was the other way around?
    Anyone got vids? when did you guys change your belt?
  14. Sep 23, 2013 at 8:12 PM
    pinktaco808
    got video cause hard to believe.
