Serpentine Belt / Pulley - Constant Squeal
Discussion in '4 Cylinder' started by TroutBum, Dec 25, 2009.
  1. Dec 25, 2009 at 6:28 PM
    TroutBum
    TroutBum [OP] Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
    I've noticed a little bit of squealing from under the hood in the morning a few times, figured it was just due to the cold / damp weather this fall/winter. Always went away after the truck warmed up a little. Today the squeal has become constant. I'm guessing it's either the belt or a pulley (33,000 miles). I'm going to pick up a new belt tomorrow when the parts store opens. Hopefully that's all it is and it'll be a quick fix...
  2. Dec 25, 2009 at 6:53 PM
    TroutBum
    Michigan
    Leer 100R
    Hopefully I can find one in stock tomorrow. Thanks for the advice, I'll let you know how it turns out.
  3. Dec 26, 2009 at 6:57 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    i had that problem and replacing the belt fixed it for me.
  4. Dec 26, 2009 at 2:06 PM
    TroutBum
    Michigan
    Leer 100R
    For whatever reason, the squealing wasn't nearly as loud today. It's still there, but I have to be outside of the cab to hear it. Couldn't locate any of the pulleys in town, one parts store did have a belt though.
    For now, I might just go with the "drive it until it breaks/gets worse" theory. Hate to just start replacing parts if I can't figure out what is actually wrong. If it gets worse, I'll order the parts and tear into it next weekend.
  5. Dec 28, 2009 at 1:03 PM
    VLANDER005
    VLANDER005 Well-Known Member
    96 YODA, 2.7 I4, 31" MTR's
    31" Goodyear MTR's
    I would start with the belt. Pick up a can of belt dressing and lightly spray the belt. If that takes car of the problem, I would lean towards replacing the belt. If it doesn't, I would lean towards one of the pulleys as taco4x4 said above.
  6. Dec 28, 2009 at 1:06 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    If you're replacing the idler pulley, replace the belt too. It's $25 and no additional labor. Better to do it all at once and not have to worry about it for a few years.
  7. Dec 28, 2009 at 3:09 PM
    TroutBum
    Michigan
    Leer 100R
    Thanks guys - the squeal went away completely today. However, with the hood open and the defrost on I did notice a slight hum. Don't remember if it did that before, but maybe the AC compressor is on the way out?
  8. Dec 31, 2009 at 11:24 AM
    TroutBum
    Michigan
    Leer 100R
    After being gone for a few days, the squeal came back today. Picked up a new belt, and checked all of the pulleys. I did notice a little slop in the pulley on the tensioner, but everything else seemed ok. Put the new belt on - no more squeal. :)
