Serpentine Belt & Pulley Job - Which Pulleys Should I Be Replacing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by awoit, Jan 5, 2023.
  1. Jan 12, 2023 at 6:39 PM
    Blain
    Blain I ain't got time to bleed
    Tx
    Just replace them all. I just did them on my 2006, easy peasy.
    Leomania likes this.
  2. Jan 12, 2023 at 7:21 PM
    awoit
    awoit [OP] Well-Known Member
    CA
    08 TRD, SR5
  3. Jan 12, 2023 at 7:59 PM
    Blain
    Tx
    I bought OEM and either used the washer it came with or reused the old one. Didn't use any inserts.
  4. Jan 13, 2023 at 7:30 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    You can use the oem washer if you want. It just provides the sealed bearing some added protection from debris.
  5. Jan 14, 2023 at 11:50 AM
    awoit
    CA
    08 TRD, SR5
    I'd want to use the insert in regardless of whether or not I use an additional washer though, correct?
  6. Jan 14, 2023 at 3:00 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Yes, the insert centers the pulley.
    Taco 422 and awoit[OP] like this.
  7. Jan 23, 2023 at 9:21 PM
    awoit
    CA
    08 TRD, SR5
    Ok y'all.. Is there a special method used to torque down the tensioner pulley? My best guess is to use the allen key in the hole to keep tension off, and then continue with the torque wrench (going Lefty since it's reverse threaded). Is that a solid way of doing it or am I missing something?
  8. Jan 24, 2023 at 7:11 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    It has a fairly low torque spec, so you won’t have any trouble tightening it up. I’m pretty sure I did it with the belt off so I probably had the allen key still in place.
  9. Jan 24, 2023 at 7:19 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Oftentimes I tighten those just by torquing against the spring stop. It doesn't need a very tight torque, around 20 lbs is fine most of the time. You're not gonna hurt it, If the tensioner arm was that brittle they'd be breaking all the time
