serpentine belt question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bassetdad, Sep 21, 2009.
  1. Sep 21, 2009 at 9:45 AM
    Bassetdad
    Bassetdad [OP] What if God Smoked Cannabis
    Harrison, Ohio
    2001 De-Badged SR5 Access Cab 2.7 / 5m
    Access Tononu Cover AFE Pro-Dry S Drop-in Filter American Mag Wheels Bilstein 5100's Black Billet Grill Clear Taillights Perma-Tech sprayed Kennesaw Mountain Rear Bumper Michelin Tires PIAA Driving Lights PIAA Headlights Piaa Tail Light Bulbs Tinted Windows – 50% Toytech AAL URD Short Shifter Tranny - Mobil 1 Engine - Mobil 1 Custom Three Bike In Bed Rack New Toyota Undercoated Frame Clear LED 3rd Brake Light
    Hi Everybody,
    I have a 2001 Tacoma 4x4 2.7 engine/ 5M with 108,000 miles. My question is when should I change my serpentine belt :confused:
  2. Sep 21, 2009 at 10:24 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    About every 50k-60k. It's cheap insurance.
  3. Sep 21, 2009 at 10:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    :confused: I don't think it has a serpentine belt.
  4. Sep 21, 2009 at 10:36 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    +1. I agree, although newer high quality belts will last longer. Just check the ribs for cracking and when you do replace the belt, inspect the tensioner. Make sure the pulley spins freely without noise and that there is tension in the spring. You will be able to feel the tension when you remove the belt.
  5. Sep 21, 2009 at 10:39 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    You are correct, the 2001 2.7 uses multiple belts. My 2008 has a serpentine belt.
  6. Sep 21, 2009 at 10:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    There is one belt that drives the power steering and altenator. And there is one belt for the A/C.
  7. Sep 21, 2009 at 10:42 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    These new belts last forever. I replaced mine at 150,000 and I swear the things still looked new with no wear, cracks, etc. But... they are easy to replace so if you want to- go for it.
  8. Sep 22, 2009 at 8:13 AM
    Bassetdad
    Harrison, Ohio
    As usual you guys are great. Thank you for the education on my 2.7 engine.
  9. May 14, 2010 at 6:05 PM
    Robert Martinez
    Robert Martinez Member
    Taco Rob
    Orange County
    2005 Toyota Tacoma PR
    Cold Air Intake FlowMaster 40 Series Iridium Plugs
    What is the best aftermarket replacement serpentine belt for my 2005 Tacoma and why? I ask as I replaced my old belt 50k miles ago and I want to change it before summer. I have heard that Good Year or Dayco make a belt that reduces friction along the side or face of the pulley. I currently have a Gates belt as they NEVER left me stranded when I was a truck driver.
  10. May 14, 2010 at 6:15 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    I replaced mine with a Gates and it jumped off one notch and shreaded the belt. Figured it was me since I had a hard time getting it on as the gates was quite a bit thicker than the stock one, replaced it with another Gates, same thing.
    Went to the dealer and got one, way cheaper (I think the gates was 60 and the one from the dealer was 25!) and no problems.
