Serpentine belt replacement. 2011 V-6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gregzz, Jan 17, 2020.
  1. May 8, 2022 at 7:25 AM
    #41
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Mmm let me see.yes 7PK2120 from Amazon.
    Quality looked great, it fit easily and then was tight when you release the tensioner. I started it for about 10 seconds and then got back under to make sure it was on everything correctly. I’ll be driving it all week for work maybe 10-20 miles per day
  2. May 8, 2022 at 7:26 AM
    #42
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Too late for me but I’ll see if mine starts squeaking.
  3. May 8, 2022 at 10:19 AM
    #43
    GreggyG
    GreggyG Well-Known Member
    thank you.
    Alexely999[QUOTED] likes this.
  4. Nov 20, 2024 at 7:15 AM
    #44
    Tacoma112
    Tacoma112 Member
    2011 Black Tacoma trd
    so did you replace just all three pulley and put better bearing in them little confused?
    #44
  5. Nov 20, 2024 at 7:56 PM
    #45
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    The bearing replacement is usually only done on the tensioner pulley. You can’t buy the tensioner pulley separately from the assembly, and it’s more work to install that than just the pulley, so it often just gets a bearing replacement. The other pulleys are replaced with new assemblies.
  6. Nov 20, 2024 at 9:57 PM
    #46
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You put the bearing in the TENSIONER pully.
    You drive your old bearing out of the pulley, and replace it with a new one.
    The idlers, you replace the the whole thing. The pulley and all.
    Also, the bolt for the Tensioner pulley is LEFTHAND thread.
    Clockwise will LOOSEN the bolt. (The opposite of a normal bolt)
