Serpentine Belt Replacement 4 cyl specific
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FLJB, Mar 5, 2016.
  1. Nov 24, 2018 at 3:54 PM
    Markcal
    Markcal Well-Known Member
    Did you buy your OEM belt from the dealership?
    Black97v6MT likes this.
  2. Nov 24, 2018 at 6:26 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    Toyota oem part 90916-02708 w/AC $82.47
  3. Dec 4, 2018 at 9:38 AM
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    I just replaced mine at 141k. Wasnt slipping yet. Figured it was time. Its such an easy replacement, i just went with something from rockauto. No issues.
  4. Dec 4, 2018 at 9:41 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I use dayco or gates belts. They are cheaper and just as good as oem
    DGXR likes this.
  5. Feb 6, 2019 at 5:16 AM
    Formica17
    Formica17 New Member
    2009 2.7 I4 RWD
    This might be simple and I’m overthinking it, but how do you read the wear marks on the tensioner?
    Black97v6MT and wags like this.
  6. Feb 6, 2019 at 6:01 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I did mine a few years ago and used a USA Dayco belt from Auto Zone- not all stores stocked it but I found one locally. IIRC it was ~$25. No issues after 20k+ miles. The belt routing is a bit challenging to remember so I printed a small pic of it and taped it to the top of the air filter cover.
  7. Feb 6, 2019 at 6:20 AM
    Markcal
    The only way I have heard to tell when a serpentine belt needs to be replaced is to use one of these tools, which I had sent free to me after watching "The Humble Mechanic" on Youtube:
  8. Feb 6, 2019 at 6:54 AM
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    The two marks are the good range, if the line on the tensioner is within the two lines it’s good, if it’s outside of the two lines it’s worn out
    weeksz, D2. and Formica17[QUOTED] like this.
  9. Feb 6, 2019 at 6:59 AM
    Formica17
    2009 2.7 I4 RWD
    Appreciate it!
    Newfiebruh[QUOTED] likes this.
  10. Feb 6, 2019 at 11:08 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I reached the tensioner from the top with a breaker bar and 14mm socket. The breaker bar has a pivot at the socket, but a ratchet does not. Easiest belt change I ever did.
    Any of the name brand belts will be good quality: Bando, Continental, Goodyear, Gates, etc. They all have the same basic construction and use EPDM, a synthetic rubber that lasts a very long time.
  11. Apr 29, 2019 at 10:38 AM
    Reinhardtius
    Reinhardtius Well-Known Member
    07 Base 2.7L 5SP
    Folks, my belt and tensioner was replaced in 2015 at 75,000, with a NAPA belt. Now at 93,000 it is squeaking, and it sounds like it is slipping, especially when accelerating and when cold. I will check the indicator marks on the tensioner this afternoon.
    The mechanic who performed the work said that I should just take the slack out of the belt by adjusting the alternator on its bracket, but I see no articles on how to move the alternator. The tensioner should be good, but I welcome your suggestions. There is a NAPA just two blocks from me and I am sure they would be glad to take my money for another belt.
  12. Apr 29, 2019 at 1:22 PM
    DGXR
    Friend
    Sacramento, CA
    Usually you will have either a belt tensioner or an adjusting bracket on the alternator, not both.
    Reinhardtius[QUOTED] likes this.
  13. Feb 6, 2020 at 5:04 AM
    T12DELAY
    T12DELAY Active Member
    Oregon
    2003 Tacoma | 2.7L | SR5 | 4 Cylinder | 2 Years of ownership
    1 fixed part = 2 broken parts
    So I bought belt set off Amazon and it was the correct ones, I need an AC, Power steering, and Alternator belt but what I didn’t see was that it says it fits 2.4L and I have a 2.7L am I screwed here? Or could it still fit
  14. Feb 6, 2020 at 1:08 PM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    Very nice write up! My 2012 is nearing 100,000 miles but no squeaks, slipping and still looks pretty darn good. Still think I'll replace @ 120,000 miles to play it safe since pretty simple change out. AND will probably use a Toyota OEM belt......
  15. Feb 6, 2020 at 4:32 PM
    #35
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    Changed my out at 75000 miles with a Gates purchased off of EBay for $30.
    #35
  16. Apr 20, 2020 at 9:48 AM
    #36
    FLJB
    FLJB [OP] Well-Known Member
    J
    FL
    2020 4X4 Sport MT
    Guys:
    OP here, sorry for not responding, I had forgotten I made this post:D:D and lots of times I don't login to browse:oops:.
    I still have the NAPA belt from the original post installed and no issues or squeals and never have in 75,000 miles. I did keep the old belt as a spare in case something happened.
  17. Aug 25, 2020 at 8:36 AM
    #37
    wags
    I stand corrected on my earlier post: Just replaced belt @ 98,382 not 120,000 mi. And used a Bando belt not Toyota ($30 vs $82) purchased from NAPA. Original belt still looked good but piece of mind. Very simple procedure.
  18. Sep 19, 2020 at 12:07 PM
    #38
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Nice and easy. 11 years and 113K on the original belt, threw in a new Bando just now. Better to replace it when I choose to versus waiting for a tow especially with the cold weather upon us.
  19. Sep 20, 2020 at 11:55 AM
    #39
    BillsSR5
    bill
    2014 SR5
    had a weird noise coming from my front passenger side this morning after a cold night, sounded almost like the plastic fan blades hitting the fan shroud and this was while I was accelerating for about 10-12 minutes until it warmed up then everything was as normal, checked the tensioner marks and was still in play but kind of favoring the left hash mark on the tensioner arm, I have 124k miles on the original belt may be time for a new one, will have to investigate further tommorrow with the hood up to make sure its the belt, kinda thought it might be the water pump but no leaks or overheating.
  20. Sep 20, 2020 at 4:33 PM
    #40
    ABA180
    East Bridgewater MA
    At 124K I'd say it's time regardless, just for peace of mind. In MA it's getting colder so I figured at 11 years and 113K it was time
    Black97v6MT and BillsSR5[QUOTED] like this.
