Serpentine Belt Replacement 4 cyl specific
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FLJB, Mar 5, 2016.
  1. Sep 20, 2020 at 4:52 PM
    #41
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    im starting to think it may have been the fan clutch making the noise im going to check it out tomorrow, I was having a real funny noise just like the fan blades hitting the plastic shroud was messing with it doing some tests, this type of noise is the first time ive heard it, ill let it cold soak overnite pop the hood tomorrow and see where its coming from after some driving went away today getting to operating temp within no more than 10-15 minutes. im going to try these tests
    https://www.youtube.com/watch?v=WzhlACxqeqQ
    Black97v6MT likes this.
  2. Sep 20, 2020 at 5:38 PM
    #42
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Not a bad idea, I'd think if the serpentine belt was really that far out of tension you would be prone to pitching the belt. Keep me posted..but still I'd say change the thing anyways at that mileage
    Black97v6MT and BillsSR5 like this.
  3. Sep 20, 2020 at 5:54 PM
    #43
    BillsSR5
    bill
    2014 SR5
    im going do a few tests with the fan clutch not too hard to do, if it pans out ill get a new OEM belt 90916-02708 they've come down in price quite a lot and Made in Japan https://parts.conicellitoyotaofconshohocken.com/oem-parts/toyota-serpentine-belt-9091602708
    Black97v6MT and ABA180[QUOTED] like this.
  4. Nov 29, 2020 at 3:51 AM
    #44
    Mongo1958
    Mongo1958 Well-Known Member
    Van
    Newnan, GA
    2015 Bright White Access Cab w/convenience pkg.
    Carbon filter removal. Intermittent Wiper Stalk. Cruise Control. Fog Lights.
    Excellent write up and photos. Maybe you could help me out, do you know the OEM part number of the 2.7L belt?
  5. Nov 29, 2020 at 8:26 AM
    #45
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    All.....you really don't need a tool (gage) to see if the belt is worn.
    Look at the pulleys. If the crest (point) of the grooves is shiny, then the belt is worn. This comes from the belt sitting deeper in the grooves with the pulley crests being driven by the valley of the belt.
    The belt is designed to drive on the sides of the V.
    Other clues to belt replacement are shiny (glazing) belt (drive side or back side), cracks (anywhere) and slipping (of course). Generally, these indicators are evident before slipping begins.
    One more tip. While the belt is off, take a couple minutes to inspect and clean the pulley grooves.
    1schoir and Mongo1958 like this.
  6. Nov 30, 2020 at 6:56 AM
    #46
    Mongo1958
    Van
    Newnan, GA
    Disregard my post above. I see the new part number is 90916-02708.
  7. Nov 30, 2020 at 7:03 AM
    #47
    BillsSR5
    bill
    2014 SR5
  8. Nov 30, 2020 at 7:34 AM
    #48
    ABA180
    East Bridgewater MA
    Mine looked okay at 113K but I managed to come into a free OEM replacement, being that the winter is coming I just said fuck it and changed it along with the spark plugs it definitely needed.
  9. Nov 30, 2020 at 7:39 AM
    #49
    BillsSR5
    bill
    2014 SR5
    OEM belts are better than aftermarkets, even tho there are BANDO aftermarket belts they aren't as good quality as an OEM BANDO as far as longevity and noise issues, plus ive noticed the OEMs are coming down in price to around $45 lately
  10. Dec 19, 2020 at 6:08 AM
    #50
    ABA180
    East Bridgewater MA
    No sir.
    Your belt is listed at 90.5 inches here https://www.vbeltguys.com/products/4060905-goodyear-oem-equivalent-serpentine-poly-v-belt
    The Google machine refers to this as a replacement for your belt, which is listed as 90 inches https://mechanidrive.com/900k7-7pk2285-2010-toyota-tacoma-equivalent-serpentine-belt-ab881318/
    I'm not saying that exact brand is good or not per se just that it's where I found the measurement.
    "Could" you try to get away with using the one you have? I suppose. Would I suggest it? No. If the slack pitches the belt, best case you're stuck and worst case it damages something else.
    The belt is cheap enough and a fast change, I have a '10 with the same engine.
  11. Jul 3, 2024 at 8:12 AM
    #51
    Crobran
    Crobran Well-Known Member
    Texas
    `21 DCSB 2.7L Silver Sky
    Trifecta 2.0, Ionic Nerf Bars, Tailgate anti theft device from @christian06, Husky Weatherbeaters, Bed lights, OEM bed mat, Derped badges and grille bezel
    This is an old thread, but thanks for posting this. It looks like I need to do this on my 2021 (already).
  12. Jul 7, 2024 at 10:03 AM
    #52
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    2nd this. I recently replaced my tensioner and belt, did it all from above so you can skip the “drop the skidplate” step. A much easier job than a European car that sometimes requires special tools. I’d say it took about 30min for belt & tensioner but that’s with me checking the idler pillows and inspecting the others for damage/freeplay/wear.
