Serpentine belt replacement? Replace Pulleys and tensioner also?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thebrotherhood08, Jul 10, 2024.
  1. Jul 10, 2024 at 4:52 PM
    thebrotherhood08
    thebrotherhood08 [OP] Member
    2016 Black TRD Off Road
    Gonna be replacing my drive belt soon. Rockauto is recommending to replace tensioner also and my father in law who’s worked on cars his whole life said to replace all of the pulleys as well.
    should I be replacing the pulleys and tensioner for this job as well? Or will the belt only suffice?
  2. Jul 10, 2024 at 5:13 PM
    Bishop84
    Bishop84 Well-Known Member
    The 4.0 was known for this, but the 3.5 not so much.
    Replace the belt and check all the pulleys while its off.
  3. Jul 10, 2024 at 7:39 PM
    BlackTRD4Me
    BlackTRD4Me Well-Known Member
    Sean
    2017 Toyota Tacoma Off Road
    Bull bar with lights, Wheels on stock tires, window vents.
    I replaced my belt at 100K for no reason other than piece of mind, No other issues so I think check the pulleys and go from there.
  4. Jul 11, 2024 at 12:11 PM
    mrh2727
    mrh2727 Well-Known Member
    Mathew
    DFW
    2023 TRD off road Barcelona Red
    Personally I would just inspect and repair if necessary. If changing them out gives you peace of mind then go for it.
    Stevie17 likes this.
  5. Jul 11, 2024 at 12:30 PM
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    I’m on all factory idlers/tensioner at 400k. Replaced one belt at 200k due to squeal
