Serpentine belt replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toywoodsguy82, Dec 22, 2019.
  1. Dec 22, 2019 at 4:09 PM
    Toywoodsguy82
    Toywoodsguy82 [OP] Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    So I’m at 140k on my ‘07 and I notice a squeal when my truck is cold in the morning. It goes away when the truck warms up though.
    I haven’t noticed much if any wear but the squeal has me slightly concerned. Your thoughts??
    replace or don’t... that is the question.
  2. Dec 22, 2019 at 4:11 PM
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
    Check the idler pulleys also...
  3. Dec 22, 2019 at 4:13 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    is the 35 bucks to replace a 140k mile 13 year old belt worth your frustration when your current one goes south.
    You need to pull the current belt off and spin everything by hand anyways to make sure things are still smooth and tight (which could cause squeaking if they are not).... so may as well pop a new belt on and save the old one while you are at it.
    Blockhead, Sprig and TheDevilYouLove like this.
  4. Dec 22, 2019 at 4:38 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    At that age and mileage I’d replace the belt and all three idler pulleys with OEM.
    Rob MacRuger, b_r_o and whatstcp like this.
  5. Dec 22, 2019 at 4:41 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    PzTank and Jeremy M. like this.
  6. Dec 22, 2019 at 5:19 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    What he said. Dude just replace it. Even if it wasn’t squeaking, at 140000 miles and 13 years old it’s a good idea to replace it to avoid a problem at some time and place where it could be a real problem.
  7. Dec 22, 2019 at 5:37 PM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    Did mine last week. Didn’t change the entire pulley, just bearing which cause you 10 bucks
  8. Dec 22, 2019 at 9:59 PM
    TacoTuesday1
    FL
    I need to figure out how to replace the pulleys; seems someone already posted a DIY.
    Already received the OEM belt I ordered for preventative maintenance piece of mind. Previous one was a Continental I think, with the weird rib design.
    I would wonder where exactly the squeak is coming from. Mine is a manual, so the squeak is coming from the throwout bearing, not the accessory drive.
  9. Dec 23, 2019 at 5:55 PM
    rayban1
    rayban1 Well-Known Member
    Seattle
    2015 tacoma sport 4x4
    truck covers usa roll cover, popnlock remote lock, iron cross running boards, p2 trailer Brake, rear view mirror upgrade with auto dim temp and homelink, yakima rack bars , goodyear wranglers, heated side mirrors with directional signal.
    Mine did it the squeal at 30,000. Changed it out all good.....
  10. Dec 24, 2019 at 2:07 AM
    Jeremy M.
    Jeremy M. Well-Known Member
    Fort Drum, NY
    13 DCSB TRD Off Road
    Definitely change that belt with an OEM part. I plan to do mine at 100k as soon as I get back from Korea.
  11. Dec 24, 2019 at 4:36 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Dirty idler pulleys can make alot of noise. A little scotch brite works well to clean them up.
  12. Dec 24, 2019 at 11:38 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Mines at 127,000 just started to squeal first start of the day
  13. Dec 24, 2019 at 11:52 AM
    Toywoodsguy82
    Patrick
    Oregon
    that’s the only time mine squeals is first start of the day.
    Alexely999[QUOTED] likes this.
  14. Dec 24, 2019 at 11:55 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Start with the tensioner pulley and go from there
  15. Dec 24, 2019 at 7:53 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I replace the belt every 30k don’t care how good it looks.
  16. Dec 25, 2019 at 4:46 AM
    TheDevilYouLove
    Marylandistan
    Have you had issues in the past? That’s pretty frequent.
  17. Dec 25, 2019 at 9:05 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Military? I'm not, but have been there several times. I feel your pain...
  18. Dec 25, 2019 at 9:10 AM
    gotoman1969
    I drive a lot so it’s basically so I’m not stranded. I keep the one that came off in the truck. Sometimes I’m out in the middle of no where.
    b_r_o likes this.
  19. Dec 25, 2019 at 9:33 AM
    TacoTuesday1
    FL
    I heard of people doing it at 90k on passenger cars; 30k seems like a lot
  20. Dec 25, 2019 at 5:52 PM
    Jeremy M.
    Fort Drum, NY
    Yes, I’m at Camp Humphreys until 2021, my brother-in-law has my Tacoma until then.
