Serpentine belt slipping on AC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oggy, May 13, 2014.
  1. May 13, 2014 at 10:57 PM
    Oggy
    Oggy [OP] Well-Known Member
    David
    Phoenix, Az
    2010 TRD Off Road
    I noticed my truck has a sequel coming from the serpentine belt for a little while, off and on. I decided to get some Prestone belt dressing spray to help eliminate the squeel. Upon squirting it on the exposed pulleys I could find I noticed my ac pulley wasnt spinning and a slight squeek was coming from the belt. Didnt over spray it since my radiator fan was blowing it everywhere but the pulleys.
    Normal for our truck or should I take it to get a new belt? Bought it used but I have all maintanence covered for this with the warrenty I got with the truck.
    I should also add my AC is still pretty damn cold and I live in AZ.
  2. May 14, 2014 at 1:08 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Belt dressing is a waste of money IMO. Get a new belt and check the idler pulleys to make sure you don't have a bearing going south.
  3. May 14, 2014 at 6:23 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    How many miles? I went 170K before I changed my OEM belt.
    no belt dressing ..... EVER! That stuff is the devil in a can, not to mention the mess that it makes. Clean everything with brake cleaner, check your pulleys and bearings, put on a new Gatorback belt.
    BTW, the belt gets replaced from the bottom. Make yourself a diagram before you pull it off. Its a really big belt looped through like a snake.
  4. May 14, 2014 at 6:31 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Are you sure the pulley on the A/C compressor wasn't spinning? I'm willing to bet that it was, and only the front clutch plate and the compressor shaft was stationary, which can be normal any time the clutch is not energized. X2 on no belt dressing and all the other advice given.
  5. May 15, 2014 at 10:07 PM
    Oggy
    David
    Phoenix, Az
    2010 TRD Off Road
    Let me put it this way, the pulley would stop spinning. I could watch it just stay still as the belt spins on it and it would randomly start spinning again.
  6. May 16, 2014 at 12:25 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    You may have an issue with the AC Compressor binding.
  7. May 16, 2014 at 7:48 AM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    I've heard of ac compressors seizing. I believe the clutch locks up or something.
  8. May 16, 2014 at 9:16 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    didn't say the miles; but it could be a belt; if the squeal stops with the dressing (dressing is only good for testing anyway). Then get a new belt and be certain the pulleys/tensioner are not binding up.
    There is a chance that the ac is failing with the compressor starting to fail internally (too much load on the belt)
    Too bad we had to get delphi compressors in our trucks.
