Serpentine belt squeaking at <20K miles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD-Troll, Jan 11, 2021.
  1. Jan 11, 2021 at 11:55 PM
    TRD-Troll
    TRD-Troll [OP] Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    2019 OR with 19K miles (no engine mods)
    Started having a squeaking or squealing noise when driving. Seems to come from the engine compartment and increases in pitch and speed when accelerating (not able to hear at idle). Seems to be more noticeable when the engine warms up. Belt does not seem to be loose.
    Was wondering if anyone had issues with the belt or pulleys at this low of mileage already?
  2. Jan 12, 2021 at 12:19 AM
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    Shoot the idler pulley bearing with some WD40 or Tri-flow.
    Bravo64 likes this.
  3. Jan 12, 2021 at 2:12 AM
    Ricertruc
    Ricertruc Well-Known Member
    17 OR4B4 06 Prerunner
    ADS CO Icon UCA AAL SCS Rims KO2s Fox 2.0 CO
    More than likely the belt. There is a thread about squeaking 3rd gen belts that I found and I suspected the idler pulley. My 2017 did it the same thing @40k and I replaced the belt with a new OEM one and the problem disappeared.
    Mikerr24, EastVanTaco and Skydvrr like this.
  4. Jan 12, 2021 at 3:33 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Take it to the dealer . So it’s documented if the pulley fails .
  5. Jan 12, 2021 at 5:02 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Is it Squealing or Just some ticking like Sound coming from below the steering wheel area sound louder if you turn your head toward the side (Your ear facing the front) ? Sound louder upon acceleration or higher engine load. If yes I may have the answer if not then warranty time.
  6. Jan 12, 2021 at 5:24 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Take it to the dealer:
    shakerhood and mattleg like this.
  7. Jan 12, 2021 at 3:39 PM
    TRD-Troll
    NV
    2019 TRDOR DCSB AT
    It is louder when accelerating with RPM increase and sounds like a squealing noise. I can hear a mild ticking noise when it is idling. But it has always done that if I remember correctly. I mostly hear it when on the highway.
    I am scheduled with the dealer for the fuel pump recall next week so I guess I will add this to the list for them.
    bulalo[QUOTED] likes this.
  8. Jan 24, 2021 at 11:40 PM
    TRD-Troll
    NV
    2019 TRDOR DCSB AT
    Dealer replaced the belt with the V-ribbed one per the TSB and the noise is gone.
    bulalo and Kev250R like this.
  9. Jan 25, 2021 at 12:55 AM
    tacochep
    tacochep Well-Known Member
    Phoenix AZ
    2019 S White Taco DCSB TRD 4x4
    scs ray 10's, demello sliders, meso stuff
  10. Jan 25, 2021 at 5:00 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    deodorant works too
  11. Jan 25, 2021 at 8:35 AM
    TRD-Troll
    NV
    2019 TRDOR DCSB AT
  12. Apr 17, 2022 at 2:59 PM
    Mikerr24
    Mikerr24 New Member
    2019 Tacoma SR5 4wd
    i just had this exact issue on my 2019. I swore it was the top right idler pulley crapping the bed so I went and bought a new one and installed it and with no results. I returned it and bought a new belt, low and behold that fixed the noise. Truck has 44k miles. I’ve had belts in the past last me 100k miles. Guess they must of got a bad batch from China or something??
  13. Apr 17, 2022 at 3:23 PM
    stuttgart1
    stuttgart1 Well-Known Member
    2019 TRDOR
    My 2019 TRD Off-road belt started making a rotational squealing sound at 28k miles. Checked all idler pulleys and tensioner all good. Replace the belt and noise gone. Here in central Oregon they spread red cinder rock on the road in winter as a traction aid. The smooth side of my belt was a reddish brown color and I believe was contaminated by the cinder rock debris.
  14. Apr 17, 2022 at 3:25 PM
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    Ended up changing my belt at home after taking it to the dealer. OR '19 @ 37k
  15. Apr 17, 2022 at 4:33 PM
    Spidicus
    Spidicus Well-Known Member
    Nevada
    19' DCSB TRDOR 4x4
    Yup its a recall on the belt. Go have the dealer replace. Mine was done. Problem solved
