serpentine belt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by geerts016, May 30, 2011.
  1. May 30, 2011 at 9:49 AM
    geerts016
    geerts016 [OP] geerts016
    SLC, UT
    08 TRD SR5 4x4
    alpine 9884 deck, auxilary LED backup lights, alpine 6x9's, alpine 6's, rockford p1000 amp, two rockford p2 10" subs, seat heaters, deezee tool box painted BSP, aero 2525 exhaust, halo projector headlights, LED light strip in hood scoop, black mesh grill, tinted taillights, window visors
    does anyone know of a diagram i can find that will give the pathway for my serpentine belt on my 2008 tacoma v6 with air conditioning
  2. May 30, 2011 at 9:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. May 30, 2011 at 9:52 AM
    geerts016
    SLC, UT
    08 TRD SR5 4x4
    awesome thank you chris, and i must say your timing is amazing.
  4. May 30, 2011 at 9:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL! :)
  5. Oct 27, 2011 at 8:43 AM
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    24 Tacoma Double Cab TRD Off Road 4X4
    Stock
    Is there a serpentine belt I can use to delete ac till I get it fixed. I was told at dealership that it's 3000.00 to get my ac fixed. The pump itself cost 1400.00!!
  6. Oct 27, 2011 at 8:43 AM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    That's because you went to the dealership
    Jessrin likes this.
  7. Oct 27, 2011 at 8:52 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    Stay away from dealer
    Jessrin likes this.
  8. Oct 27, 2011 at 8:53 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Then what is costing the remaining $1600? Labor?
  9. Oct 28, 2011 at 5:47 AM
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    Stock
    No.. They said that they can't just change the pump. They would have to change the air dryer and condenser. Then the rest was labor. I called car quest and napa for an after market pump and was told its only a dealer part. So I'm screwed for now.
  10. Oct 28, 2011 at 9:43 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    2005 TOYOTA TACOMA PRE RUNNER 4.0L 3956cc V6 FI [1GRFE] DOHC : Heat & Air Conditioning : A/C Compressor Wiki Price
    DELPHI Part # CS20055 Warranty requires other parts also be replaced, see Info page for Details (Only 4 Remaining)
    $378.79
    2005 TOYOTA TACOMA PRE RUNNER 4.0L 3956cc V6 FI [1GRFE] DOHC : Heat & Air Conditioning : A/C Condenser Wiki Price
    VARIOUS MFR Part # TO3030205 {#8846004210}
    Air conditioning condenser
    $82.79
    378+82 doesnt equal 1600
    rockauto.com
  11. Sep 21, 2014 at 1:47 PM
    Bogeyman
    Bogeyman New Member
    Fort Worth, TX
    05 PreRunner
    The ONLY time I take any vehicle to the stealership is for warranty work. And then they will usually "find" other things that need to be fixed not covered by warranty. I do a lot of my own work and have a garage I trust for the things I don't have the tools or the know how to do.
  12. Sep 21, 2014 at 2:15 PM
    Aloe
    Aloe Well-Known Member
    05 SWB TRD Sport access cab 4x4
    URD Short throw Fisher Plow
    Back from the dead...Idk if the guy still has his truck but I have a spare compressor if he is still looking, lol
  13. Jul 9, 2017 at 11:25 AM
    LeBlanc61700
    LeBlanc61700 Member
    C
    Mass
    05 TRD Off Road
    kill-switch, fog anytime
    My 05 TRD keeps throwing serpentine belt. It's running with 2 ribs off to the radiator side. Been through 3 belts before I realized ribbing (ain't to my pleasure). Still runs like a champ, though. But my ac light does flash when I turn fan on. ... and seems like power steering pulley may have play on bearing. Thoughts?
  14. Jul 9, 2017 at 11:53 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Running the defrost mode engages the ac pump.
    I pulled the relay until I could do my compressor.
  15. Jul 9, 2017 at 1:18 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Don't forget to check your idler pulleys. If you have over 100K, you're likely to have one or more worn out bearings. The tensioner is a commong bearing to wear out. This happens to be the easiest bearing to replace.
  16. Jul 9, 2017 at 6:19 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    :popcorn:........sub'd
