Serpentine Belt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Syncros, Jan 21, 2012.
  1. Jan 21, 2012 at 2:59 PM
    Syncros
    Syncros [OP] Well-Known Member
    What an appalling design. Ive owned this truck for a year, looking back on its records its had problems with the serpentine since it was new. Previous owner actually included a new belt with it in one of the storage compartments under the seat.
    Anyways,
    All of the idlers are good, the bearings are smooth with slight resistance (yes I know how a new, good bearing feels so don't question me). The problem is the belt keeps getting glazed on the smooth side. I have to replace it frequently and its not cheap, not to mention its a piss off to be under my truck in cold, rainy, snowy weather doing that.
    Today I decided to solve it for good, pressed the bearings out of the idlers and sandblasted the pulleys, scotch brited all of the accessory pulleys, cleaned it all with solvent/degreaser and compressed air. Fire it up and its still chirping.
    Any idea's? I can't pin point it with my stethoscope, I really have no idea anymore. Belt is a Dayco poly rib, If I put a slightly used OEM Toyota belt on its worse (its not glazed).
  2. Jan 21, 2012 at 3:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Most all chirping is due to an idler puley. Even though they may feel fine, they can chirp.
  3. Jan 21, 2012 at 3:12 PM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    is your tensioner puttin enough tension on it? try while its running pull an put more tension on the belt and see it if goes away
  4. Jan 21, 2012 at 3:12 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Good idea^^ but don't touch the belt while running haha. Only try the tighten the belt
    More using a wrench/ratchet on the tensioner.
    Use a stethoscope to pinpoint the noise. If you cant, replace them or deal with the noise
  5. Jan 21, 2012 at 3:25 PM
    Syncros
    May have found a culprit i'l report back in a half hour if I got it figured out
  6. Jan 21, 2012 at 3:40 PM
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
    Same issue here, interested in what you find...
  7. Jan 21, 2012 at 3:56 PM
    Syncros
    Nope. But at least it only squeals above 2000rpm now. :rolleyes: I guess I will have to be "that guy" with the squeaky belt. Fed up with working on it for now.
    This is with the Defrost turned off also and all electrics off so there's the least load on the belt system, who knows what will happen when I tur everything on.
    Im a Toyota guy so its kind of sad to see the drop in quality and lazy design work, the truck has other issues too (cold start piston slap, exhaust flutter under load, loose access cab doors, TSB springs are S shaped) could go on...
  8. Jan 21, 2012 at 3:59 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Maybe you should swap to a gates or gatorback belt.
  9. Jan 21, 2012 at 4:02 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    That's the crap toy belts, had the same problem with my wifes corolla, I changed that belt 3 times and it always started up again. I had the dealer check it out and they could not come up with any problems.
  10. Jan 21, 2012 at 4:03 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    A scotch-brite pulley is no comparison to a brand new one.
  11. Jan 21, 2012 at 4:06 PM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    have u taken the belt off completly and seen if it still makes noise? just wondering
  12. Jan 21, 2012 at 4:55 PM
    Syncros
    I already bought two new idler pulleys. I just sandblasted them all which normally eliminates any squealing because it takes off the glaze. The accessory pulleys are the ones I scotch brited and cleaned with solvent, they have nothing physically wrong with them, the ribbed side of the belt is not glazed. Its a problem with the idlers, or one idler or something because its the OUTSIDE of the belt that is being glazed.
    Im going to buy one more new belt, if it starts squealing again I will just replace everything. Fed up with my expensive little truck sounding like a total pile of shit. I take really good care of this thing, more care than ive ever had to give any of my trouble free Toyota trucks of the past.
    I know what has to be done I just can't find a reason to throw any more new parts at it, the tension is in spec, bearings are all good, no red flags.
    Edit:
    Ive tested it with 3 belts, not one of them is brand new, but one is about as close as you can get, and shows no reason to be making noise. I find a brand new belt will last about 2 months before it starts slipping again. Something is not right.
  13. Jan 21, 2012 at 4:58 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    To determine if it's the belt, while the truck is running, lightly apply dish soap to the belt. If the squeeking is gone, it's the belt. If not, check the pully's.
  14. Jan 21, 2012 at 5:04 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    ^^ trust me, did the on the tundra I had. And if it IS the belt, buy an OEM one from the stealership.
  15. Jan 21, 2012 at 5:30 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    How about trying to spray some "belt dressing" on the pulleys and belt....
    I stoped my first belt squeal by doing that....(but only for a while)... I then put on a new one...no more squeal......Not enough tension could be an issue, but sounds like you have that one covered....
    Good luck....
  16. Jan 21, 2012 at 6:54 PM
    Syncros
    That stuff is for V-Belts, certainly don't want to contaminate it with anything.
    I know a new belt will fix it. But who knows how long it will last..
  17. Jan 21, 2012 at 7:02 PM
    danimal92sport
    danimal92sport Well-Known Member
    dcab, 4WD, TRD O/R
    "Belt dressing" needs to be banned from this planet. Forever.
  18. Jan 21, 2012 at 8:06 PM
    Thundjet
    Thundjet Well-Known Member
    2012, V6, Sport TRD, Auto, 4 wd
    Seems to me if the belt is becoming glazed it is slipping. Something is causing it to slip or there is not enough tension on the belt.
  19. Jan 24, 2012 at 9:14 PM
    Syncros
    Its glazed again. My truck sounds like a neglected piece of shit.
    Next step, throw money at it. Excessive amounts, for parts that should NOT be nearly as expensive as they are. Becoming less and less satisfied with Toyota, and that is frustrating because I don't like any other vehicle manufacturers.
  20. Jan 24, 2012 at 9:30 PM
    80s toysport
    80s toysport Well-Known Member
    Nikolai (Nik)
    kansas city, ks
    09 DC TRD off road
    Camper, nerf bars, visors, hood bug gaurd, ABS killswitch, bed light
    lol, i can see you just throwing money at it. Take that, and that. Hows about this lol :D
