serpentine belt
Discussion in 'Technical Chat' started by jdutton318, Sep 4, 2019.
  1. Sep 4, 2019 at 6:05 AM
    jdutton318
    jdutton318 [OP] New Member
    Joel
    07 Tacoma extended cab
    none
    I just replaced my alternator, unfortunately I broke the upper mount bolt and had to drill it out and replace the bolt. Now I have the new alternator in place and bolted up and now the serpentine belt is loose, replaced with a new one and is still loose. I have double and triple checked the routing of the belt is correct and is still loose. The tensioner is working fine, but I still have so much slack in the belt that while the engine is running the belt does not move. and I could almost take the belt off without moving the tensioner. Any suggestions would be greatly appreciated.
  2. Sep 4, 2019 at 6:14 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Before you replaced the alternator was the belt tension good, unknown, or bad? You may have (always) had a belt tension issue which was diagnosed as an alternator issue.
  3. Sep 4, 2019 at 6:18 AM
    jdutton318
    Joel
    none
    The tensioner was fine when I removed the belt, and the alternator was tested before removal with a bad voltage regulator, so that was the need for replacement.
  4. Sep 4, 2019 at 8:55 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Possible the new belt is not the correct one.
    Lester Lugnut likes this.
  5. Sep 4, 2019 at 8:57 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    This has to be it.
    Should be a significant amount of tension on that belt
