Serpentine belt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by catfish559, Jan 7, 2020.
  1. Jan 7, 2020 at 10:32 AM
    catfish559
    catfish559 [OP] Member
    Madera,Ca.
    2017 Tacoma TRD Sport 4X4 DBL CAB Long Bed
    changing out the Serpentine belt ,truck just hit 100,000 miles nothing wrong with the belt just doing it for maintenance wise . Question is there anything else i should replace since ill have the belt out like pulley or tensioners? no squeaks or noise with truck just doing maintenance for 100000 miles.
  2. Jan 7, 2020 at 10:34 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Have you replaced the plastic coolant bypass pipe on that 2006 4 banger?
  3. Jan 7, 2020 at 10:39 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    With that mileage, I'd consider the Gates idler pulley/tensioner combo on Rock Auto. Just use the pulley from the tensioner.
    catfish559[OP] likes this.
  4. Jan 7, 2020 at 10:50 AM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    I developed a nice squeak upon cold start ups recently. Will be replacing the belt, all 3 idler pulleys, and tensioner pulley this weekend.
  5. Jan 7, 2020 at 11:17 AM
    catfish559
    Madera,Ca.
    no i
    no i have not. what is this for or do?
  6. Jan 7, 2020 at 11:32 AM
    andrew61987
    It's a pipe under the intake manifold that has been on Toyota 4 cyl engines for years. In 2005 they switched the design to a plastic pipe which turned out to be an engineering mistake as they switched back to metal in ~2009. The plastic is notorious for disintegrating, sometimes catastrophically. Mine had a pinhole leak so I replaced it and when I did the pipe fell apart in my hands like it was made from wet saltine crackers. Many many people on here have reported the same. I jus tread a story in the 4cyl forum of a guy who's failed on the freeway and caused blown head gasket and engine failure due to puking all coolant in seconds.
    It's an easy to moderate DIY job. There are all kinds of posts about it on the 4cyl forum. Everybody with the plastic bypass pipe should have it replaced with the updated Toyota metal part as soon as possible. It really should have been a recall.
  7. Jan 7, 2020 at 11:35 AM
    catfish559
    Madera,Ca.
    thanks for the information gonna look into it
  8. Jan 7, 2020 at 12:46 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    i changed my belt first time when i did my steering rack 2.5 years ago, no more starting squeaks and now have 230k with original tensioners and pulleys
  9. Jan 7, 2020 at 1:19 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I would replace the belt and three idlers with Toyota brand products. They cost 3x as much but are 10x as good. Genuine Toyota parts cannot be beat.
    BillsSR5 likes this.
  10. Jan 7, 2020 at 2:18 PM
    catfish559
    Madera,Ca.
    by any chance do you happen to know these part numbers or have them ?
  11. Jan 7, 2020 at 2:21 PM
    andrew61987
