Service Advisor/ Toyota Dealer
Discussion in 'Arizona' started by AZmohawk, Dec 21, 2020.
  1. Dec 21, 2020 at 11:48 AM
    AZmohawk
    AZmohawk [OP] Well-Known Member
    Dan
    2020 Toyota Tacoma DCSB Off Road
    Bilstein 5100s BFG K02 265/75 R16s
    Can anyone recommend a Service advisor to work with at Bell Road Toyota. This is closest to me. I might consider Right Toyota if anyone has a Great connection. Just would like to have someone I can trust. Thanks for any tips!
  2. Dec 21, 2020 at 12:22 PM
    cartter469
    cartter469 Professional Idiot
    Cartter
    Reno NV
    '17 4x4 DCSB OR
    Sliders; Skids; Diodes; 33" Falkens; Elka 2.5's; Icon Rxt
    +1 If anyone knows a service advisor who will do TSB updates. I know it varies by dealer and wouldn't surprise me if it was different from advisor to advisor.
  3. Dec 21, 2020 at 3:31 PM
    barretta
    barretta -
    San Clemente, CA
    '18 White TRD OR 4x4
    I’ve had mixed encounters with Christopher. He did do my TSB no questions asked after I described the exact symptoms. But he’s given me the run around on other things. It also says he’s in sales on their website so idk. But I stopped going after my free maintenance ran out.
  4. Dec 21, 2020 at 4:39 PM
    blank858
    blank858 Member
    Steven
    Santee, CA / Tucson, AZ
    '15 DCSB Off-Road 4x4 White
    I wouldn't recommend Right Toyota at all, they took 4 hours to do an alignment for me and had the toe and hook backwards. Took it to my normal guy and he was done in 15 minutes and corrected their mistake
    cartter469 likes this.
  5. Dec 21, 2020 at 5:04 PM
    AZmohawk
    Dan
    Thanks for the comments so far. Would also consider Camelback Toyota. It is a much farther drive but if someone has a solid connection there.
  6. Dec 26, 2020 at 11:33 PM
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    4.88, Radflo 2.5" Resi,ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack+2,front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    I bought my car at Right Toyota but free oil changes took like 3.5hrs and the parts dept charges more than retail if you don't try and force them to match camelback's online parts prices. Right Toyota also tried to charge me $218 to sync my TPS modules which discount did for free, and the service guy didn't even want to quote me much less deal with me. So I drive all the way to Camelback and I have used Mike Romero since 2013. The wait room is superior with a quiet area upstairs most people don't know about. Also I bring my synthetic oil and they do the oil changes which saves a ton, and I have a valve on my oil drain plug and they haven't messed it up.
  7. Dec 26, 2020 at 11:47 PM
    cartter469
    Cartter
    Reno NV
    '17 4x4 DCSB OR
    May try to see if mike will help me out with TSB file update, which is supposed to be under toyota extended warranty for pre owned purchases.
  8. Dec 26, 2020 at 11:50 PM
    cytocycle
    Scottsdale, Arizona
    He just helped me do the Secondary Air pump Failure on my 2012 on the new TSB extension. He's very familiar with Tacos.
  9. Dec 27, 2020 at 3:58 PM
    AZmohawk
    Dan
    Thanks cytocycle. Thats the info I am looking for.
  10. Feb 9, 2021 at 10:00 AM
    TacoTimo
    TacoTimo Well-Known Member
    Timo
    2019 TRD OR 4x4 Cav. Blue
    I know it's out of the way from where you guys are talking about but I'm scheduled to have the TSB update done to my '19 at Big Two Toyota on Gilbert Rd. Will report back later but Alex made it seem like he was aware of the forum discussions on TSB-0092-20 and is willing to get it done for me.
    Edit: TSB is done, worked with Fred at Big Two Toyota. I walked in and told him exactly what I was looking for, he put it through and now my truck drives like not garbage. Very happy, quick in and out.
  11. Feb 9, 2021 at 4:18 PM
    cartter469
    Cartter
    Reno NV
    '17 4x4 DCSB OR
    Curious if he questioned anything like larger tires(if you have) or if he simply said okay great lets get to work. Also is his last name Hottenroth? Making sure I set an appointment with the right person to save any headaches.
  12. Feb 9, 2021 at 4:25 PM
    TacoTimo
    Timo
    That's the guy. I have stock tires but I mentioned the TW thread on the TSB I was looking to have resolved as well as a description to the cal number on the ECU I was looking to have done and he just went along as if I asked him to rotate my tires. For what it's worth, what I was asking is something Toyota should be doing outright, no questions asked. I was more concerned about the fact that so many people were having a tough time at their respective dealers with it but he was cool and took care of me.
