Service Manual for 2002 xtra cab PreRunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by coryohana, Nov 6, 2016.
  1. Nov 6, 2016 at 12:00 PM
    coryohana
    coryohana [OP] Well-Known Member
    Cory
    Ventura, CA
    2002 Prerunner TRD 3.4 Auto w/locker
    *Magnuson Supercharger *OME suspension with 880 coils *Dakar Leaf Pack *SCS F5 Dark Bronze, wrapped in KO2's *Custom Diamond Back bed cover and rack with custom storage *LED exterior/interior light replacement *SS brake lines *TC LCA Cam Tab gussets *TC UCA
    Hello guys. This is my first post and new to the group. Thanks for your help. I just rolled over 107k on my truck.
  2. Nov 6, 2016 at 12:05 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Welcome. Are you asking for a service manual for your truck?
  3. Nov 6, 2016 at 12:20 PM
    coryohana
    Cory
    Ventura, CA
    I believe so. I downloaded the FSM link from a older thread, but it doesn't tell me when to change oil, hoses, timing belt. I'm looking for a manual/pdf on when to service my truck for maintenance.
  4. Nov 6, 2016 at 12:23 PM
    coryohana
    Cory
    Ventura, CA
    Unless I'm missing something?
  5. Nov 6, 2016 at 12:24 PM
    FirstGen Jer
    Jeromey
  6. Nov 6, 2016 at 12:34 PM
    coryohana
    Cory
    Ventura, CA
    Great! Thank you! Is there any differences in your manual that I need to know about? I have a 2002 Prerunner 3.4L
    Or is it pretty much the same maintenance plan?
    FirstGen Jer likes this.
  7. Nov 6, 2016 at 12:35 PM
    FirstGen Jer
    Jeromey
    01-04 tacoma's will be the same.
  8. Nov 6, 2016 at 12:41 PM
    coryohana
    Cory
    Ventura, CA
    Okay perfect. Your truck looks clean, what type of lift is that and lights? I got Adjustable Billy's front and back; I was thinking about switching out my rear leaf springs for some OME Dakars. But do i need to replace upper/lower control arms?
  9. Nov 6, 2016 at 12:57 PM
    FirstGen Jer
    Jeromey
    Lift is adj. Billys with eibach coils. Lights are cheapo Spyder lights. I have heard good things with the ome dakars. No need to ever replace your lca unless converting to long travel. The oem uca's will work for lift up to about 2.5"-3". Any more that and you would want aftermarket uca's to help with alignment specs.
  10. Nov 6, 2016 at 1:46 PM
    coryohana
    Cory
    Ventura, CA
    great. I should be good with a 2.5" lift on the front then. I figured I didn't need to replace anything. However, I still am using my stock coils. Are your lights Projectors? HID or LEDS. Either way thanks for your help!
  11. Nov 6, 2016 at 2:15 PM
    surfernv
    surfernv Member
    Nick
    2001 Tacoma Xtra cab 4WD
    OME 881 front coils. Dakar rear leafs. Nitrocharger Sport shocks all around. Snugtop topper with Yakima racks.
    That's awesome, thanks for that maintenance schedule!
  12. Nov 6, 2016 at 3:54 PM
    FirstGen Jer
    Jeromey
    Ya they are projectors with halo's and hid's. No problem glad to help.
