service question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snowgod06, Oct 21, 2009.
  1. Oct 21, 2009 at 8:30 PM
    snowgod06
    snowgod06 [OP] UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    so ive been trying to get out and service my tuck for some time now, due to work and school havent had time. wondering if at 42000 miles and no new tranny fluid, or front/rear diff. fluid if its still safe to change it out. I know that after some time that gears and such get used to the viscosity of the warn oil, and want to make sure that it wont damage anything. I have a 4l V6 6-spd and also curious what your taco nuts recomend for front/rear fluid and tranny fluid.
    thanks
  2. Oct 21, 2009 at 8:32 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Tranny fluid is good for 100,000 miles.
  3. Oct 21, 2009 at 9:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not on the manual tranny :)
    OP, change all the fluids as soon as you can. No harm can be done from changing them out.
  4. Oct 21, 2009 at 9:09 PM
    snowgod06
    Rob
    06 Access Cab
    what do you recommend for the fluid for the diffs and tranny
  5. Oct 21, 2009 at 9:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Mobil 1 75-90. If you have a limited slip diff in the rear, I recomend regular dyno oil 75-90 or 80-90 with 4 to 8 ozs of LS Diff addative.
