service recomendations for 2005 with 140,000
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chase, May 9, 2011.
  1. May 9, 2011 at 11:48 AM
    chase
    chase [OP] New Member
    San Diego
    Tacoma V6 SR5 2WD sport short bed
    Just purchased and it checks out really solid mechanically. I want to do some preventative maintenance to keep it going. Came with some records, mostly oil changes. I was thinking of having a trans service done and new spark plugs. Any suggestion would be helpful. V6 auto crew sport short bed 2wd. Thanks
  2. May 9, 2011 at 11:55 AM
    BigJLarse83
    BigJLarse83 Well-Known Member
    Salt Lake City, UT
    06 DC PreRunner TRD Sport
    When I bought my 06 PreRunner it had 70k on it so I had the trans, rear end, radiator and brake lines flushed and the spark plugs changed. I know it was a bit early on some of it but in my opinion it's a cheap preventitive. I also ran a can of 44K through the gas tank from BG.
  3. May 9, 2011 at 12:57 PM
    chase
    San Diego
    Thanks. I have a mechanic friend who is Ford factory trained and 21 years working for Ford dealer service who suggested I take it to the dealer for trans service. It also needs a battery and I've had Interstate in my other vehicles but have been told that the Toyota True Start is a good bat. They have them on special here for $119 Any thoughts?
  4. May 9, 2011 at 2:53 PM
    ChompsterTacoma
    ChompsterTacoma Well-Known Member
    Chompster
    Fresno,Ca
    TRD offroad 4x4
    Bone Stock
    I would swap out the water pump, belt and tensioner with new ones. Flush radiator, lube the yokes and for kicks and giggle repack the wheel bearings. Other than that you got banging ass truck. My bro has a 2005 too and it's well over 250,000. He had it since new and have always used it as a truck.
  5. May 9, 2011 at 3:04 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    2nd gen has chain no belt to replace.
  6. May 9, 2011 at 3:39 PM
    ratfink504
    ratfink504 Well-Known Member
    Paul
    New Orleans
    RIP 06 Tacoma Two Tone TRD Sport 4x4
    Does it really? Thats great because I was going to have mine done soon bc I'm around 135k. I do about 1k a week
  7. May 9, 2011 at 3:43 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    When Chompster said belt and pulley, he was probably referring to the serpentine belt and tensioner pulley, not the timing chain. I too would replace the serpentine belt if it looks like it's needed. And it would be a good time to check the rear brake shoes. They should be getting close to needing to be replaced. Oh, and definitely flush out the brake fluid! By 100K miles, I had a lot of air bubbles in the lines.
  8. May 9, 2011 at 9:41 PM
    chase
    San Diego
    Thanks! That's the kind of advice I was looking for.
  9. May 10, 2011 at 7:27 AM
    joes06tacoma
    Joe
    Central Coast, CA
    I would be real careful about "flushing" anything that you don't know the history on. A drain and fill only on the transmission would be safer. Sometimes they can flush out something that was holding the trans together.
    Definitely change the plugs and the gear oil in the rear diff. Consider waiting to change the coolant until you can afford to replace the radiator. I am planning to wait till 80 or 100K and then replace my coolant and radiator at the same time. I've seen too many plastic tank radiators fail. That would be a bad thing on an all aluminum engine. I don't think the wheel bearings are packable on these. I could be wrong though.
    I have had real good luck with NAPA Legend series batteries. Never had one go on me, and if I ever need one warrantied, there is a NAPA in damn near every town in america.
