Service scheduled, now what?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by okccj, Dec 23, 2016.
  1. Dec 23, 2016 at 11:14 AM
    okccj
    okccj [OP] Well-Known Member
    I just bought a new 2017 TRD OR, Auto 4x4, but after doing some reading here on the forums I got a little nervous about my transmission fluid being low and the u-joints not being greased properly. I called the dealership and set up a time next week to take the my truck in for them to verify these two items. My question, how do I verify that they actually performed the ATF check properly? How long should this take them? It sounds like this is a pretty in-depth process and I want to make sure it's done right.
    When I made the service appointment, I told the scheduler I want the AFT check to be the full manual check, but still concerned about quality service.
    Maybe I'm being a little paranoid, but reading some of these threads will do that to you. Much thanks in advance.
  2. Dec 23, 2016 at 11:17 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Step 1) Give a dealer a chance before assuming they're incompetent and shady.
    You want them on your side and not thinking you're a problematic customer.
    Step 2) Adjust the future service appointments accordingly.
    File IFR, Kyitty and patrick70 like this.
  3. Dec 23, 2016 at 11:28 AM
    okccj
    So if they come back after 15 minutes and tell me all looks good I should take that at face value?
    P.S. I wouldn't typically assume someone is shady without a reason, however, some of the horror stories on this forum about shady service jobs has my eyes wide open.
    Law950 likes this.
  4. Dec 23, 2016 at 11:31 AM
    T4RFTMFW
    No.
    But you should see if they come back in 15 minutes first before assuming that's what will happen. Your questions are good, I would just try and recommend that you give them the opportunity to fail before expecting the fail to happen.
    Lot of excellent dealerships. Few bad ones. They ruin it for everybody else (like all things).
    Kyitty, ramonortiz55 and patrick70 like this.
  5. Dec 23, 2016 at 12:20 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Follow the recommended maintenance schedule in the book, and enjoy your new truck.
    G.
  6. Dec 23, 2016 at 12:21 PM
    vale46
    vale46 Well-Known Member
    FL
    2017 TRD Pro
  7. Dec 23, 2016 at 12:45 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    In order to check the transmission properly. Its needs to be a certain temperature. If you drive the Truck to the dealership and drop it off. It will need to cool down for awhile in order to be in the proper temperature. Allow time for this. If they come back after 15 minutes and say its done. Then I would be worried about your service.
    Garyji likes this.
  8. Dec 23, 2016 at 1:00 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    assuming you live in cold country it should not take longer than 1 hour to cool down. check should take 1/2 hour after cool down.
  9. Dec 23, 2016 at 2:12 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    Depending on how far away your drive is will also determine the wait. My drive is 1hour, and I waited 6 hours for it to cool down enough for them to check it, it was worth it as it was 2 quarts low and the tranny was acting up. It was late spring when it was checked, so if it's cold where you are, it may not take as long.
  10. Dec 23, 2016 at 2:28 PM
    walterj
    walterj Well-Known Member
    PA, USA
    Sexy Black '17 Taco 4x4 DCSB TRD Off-Road 6MT
    You take a Navy grease pen and crawl under the truck and mark any bolts you expect them to have to turn. Then you take a picture with the date.
    Before you leave the dealership - crawl under an have a look, take a picture. If they match, they lied. You can decide what to do about that on your own.
    PROseur likes this.
  11. Dec 23, 2016 at 2:38 PM
    Kenstaroni
    Kenstaroni Well-Known Member
    Ken
    Nashville, TN
    2018 T4R TRD Offroad
    Icon Stage 2 285 KO2's RCI Sliders Rhino Rack Pioneer CB
    I wrote a list on my service ticket of all the items I wanted checked including a manual transmission fluid check. The girl in service told me that I had a sealed transmission that couldnt be checked. I politely assured her that yes it could be checked. Once she asked another service person, he echoed what I said and confirmed that I was correct. That kinda irritated her I could tell. She asked the guy if he could read everything I wrote down, as if my handwriting was illegible or something...lol
    Don't assume anything at the dealer. Same girl told me they checked everything as part of the 5k service, after her display of transmission knowledge I wasn't going to count on it so I wrote everything down. They turned my seat belt chime off for me which was nice of them.
  12. Dec 23, 2016 at 3:08 PM
    okccj
    I completely agree. I just want to be prepared in the event things go south.
  13. Dec 23, 2016 at 3:10 PM
    okccj
    Good idea. A list may be helpful. That way I can explicitly state "manual transmission fluid check".
    Out of curiosity, what is the other, inferior, method that can be used to check ATF on these truck?
  14. Dec 23, 2016 at 3:48 PM
    chuck1986
    chuck1986 Two in the Taco one in the Prius
    Tulsa, OK
    2017 TRD-OR Blue
    I havent heard any 2017s say they had problems with either of those issues. I doubt there are any problems.
    But peace of mind is nice.
    What dealership is it? Do some research on them. That will tell you a lot.
  15. Dec 23, 2016 at 4:24 PM
    Kenstaroni
    Ken
    Nashville, TN
    They can check for codes, but other threads have included folks that have said that they have been 3 quarts low or more but no codes are present so that doesn't appear to be an accurate way to check.
  16. Dec 23, 2016 at 4:43 PM
    Riding Dirty
    PlastiDip
    The inferior method of checking is using techstream, which is a computer hookup, isn't accurate for reading ATF level.
  17. Dec 25, 2016 at 11:58 AM
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    So is the low fluid not an issue with '17 models?
  18. Dec 25, 2016 at 12:11 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    My 17 was one off the first shipment the dealer recieved 4-5 months ago. My transmission fluid was low and had to be topped off. No real issues but I wanted to be sure it was filled to the proper levels as I was about to go on a 2600 mi road trip.
  19. Feb 2, 2017 at 3:25 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    anyone know what temp its supposed to be?
    I'm close to the dealer and its the winter. I'm wondering if I could drive there first thing in the morning and it won't get too hot.
    Or if I need to leave it overnight for them to do the test?
    I'm trying to search for the temp so I can go with more knowledge than the average customer so the dealer doesn't try and fuck around on me
  20. Feb 2, 2017 at 4:48 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    should cool down in a couple of hours....think the check temp is like 105 to 110 degrees?
