Service the transmission on 07 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CARRIERE1, May 12, 2017.
  1. May 12, 2017 at 7:56 PM
    CARRIERE1
    CARRIERE1 [OP] Member
    SHECKY. CARRIERE
    Carencro, la..
    2007 Black Tacoma prerunner. 4 doors
    Have 265/75/16. Tires
    should I take it to the dealer to get it done. Or is it something that can be done in a garage at home. Don't know how to fill trans back up with no dipstick to check the level.
  2. May 12, 2017 at 8:00 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
  3. May 12, 2017 at 8:01 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
  4. May 12, 2017 at 8:08 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I did a drain and refill in my own garage. Just buy four quarts of ATF fluid from the dealer and do it yourself.
    07 sport 4x4 likes this.
  5. May 12, 2017 at 8:18 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    10 years old and never been serviced before? stick with a drain/fill of ~4 quarts every year.
    i personally wouldn't do a cooler line flush
  6. May 12, 2017 at 8:20 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Lots of people here have flushed their transmissions at high mileage for the first time with no issues. It's up to you OP.
  7. May 12, 2017 at 8:36 PM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    Dealer can flush the entire system around 300.00 however
  8. May 12, 2017 at 8:56 PM
    redtoytaco
    redtoytaco Well-Known Member
    So Cal
    06 PreRunner Dcab LB SR5
  9. May 13, 2017 at 5:19 AM
    hardtaco
    hardtaco Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    I am a firm believer in leaving these auto trannys alone if they are under 100,000 miles and not indicating any issues. But then again, I am not a tranny expert.
  10. May 13, 2017 at 6:06 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Leave them alone and let the decide which bathroom to use
    inwood customs likes this.
  11. May 13, 2017 at 8:24 AM
    03toyfan
    03toyfan Active Member
    Josh
    North Georgia Mountains
    03 and 05 4 dr 4x4 v6 SR5
    ranch brand topper color matched ,nfab light bar on bumper spectra drop in air filter hella 500 black majic driving lights,general grabber at2 tires.
    I don't believe in urban legends.drain and fill can't hurt at any mileage.
    lynyrd3 likes this.
  12. May 13, 2017 at 8:36 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    i did mine for the first time @ 262k miles, full flush, pan drop, screen change.
    Minimal residue in the pan, six magnets in the pan had what i would consider normal particle accumulation.
    The original fluid, while dark, was still red, no burnt smell to it, no varnish on valve body.
    I've serviced GM transmissions @ 30k that had more concerning material in the pan.
    lynyrd3 likes this.
  13. May 13, 2017 at 2:07 PM
    BlueMile
    BlueMile Frozen north specialist
    Patrick
    North/Central Alberta
    2009 TRD Sport
    ATV trail dents, many, many lights, 4-6 beer cans.
    07 sport 4x4[QUOTED] likes this.
  14. May 13, 2017 at 4:31 PM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    I just ran some numbers for if you decide to do a drain only and fill. Assuming you use a full 4 quarts of fluid at each drain and fill, and round off the capacity of the tranny to 12 quarts, here is how it will break down. This is assuming the vehicle is driven long enough to mix old and new fluid completely (I have no idea how long that takes).
    Here is how much new vs old fluid you'll have at each fill and drain:
    First drain and fill: 8 Qts old, 4 Qts new (simple, duh)
    Second fill: 5.34 Qts old, 6.66 Qts new
    Third fill: 3.56 Qts old, 8.46 Qts new
    Fourth fill: 2.37 Qts old, 9.64 Qts new​
    As you can see, at about 3 drain and fills, you are replacing a much higher ratio of new fluid vs old fluid. So, in my opinion, at 3 fill and drains as long as the original fluid wasn't completely shot (burnt) then this method of exchanging fluid may be the easiest and less risky for most people.
    I'll still be doing a complete drain and fill myself, but this is an alternative with a much lower risk factor.
    2015WhiteOR likes this.
  15. May 14, 2017 at 6:05 AM
    lynyrd3
    Bill
    East Central Upstate NY
    :censored:Tech at my stealership said you never need to change the transmission fluid in our trucks !:eek: Had them do it anyway while they installed a Hayden high performance trans fluid cooler at 60000 miles . Which is when they proceeded to bend me over:( . Been a while now but they charged me around $300-400
  16. May 14, 2017 at 1:33 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    60k is the recommended interval if you tow or use your truck in severe operating conditions.
    lynyrd3[QUOTED] likes this.
