Services Recommended: Advice
Discussion in 'General Automotive' started by AKBEAR63, Jan 11, 2022.
  1. Jan 11, 2022 at 6:46 AM
    AKBEAR63
    AKBEAR63 [OP] Member
    Bear
    2018 DCLB
    Can I get advice: My wife’s car is in for service and they are recommending some different things… I don’t know how legit they are. She has a Honda CRV, 22,600 miles. They are recommending changing brake fluid, diff and fuel induction cleaning. The diff fluid has not been changed, I don’t know if this is really necessary, nor the fuel induction cleaning. Advice?
  2. Jan 11, 2022 at 7:13 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Go with the recommended Honda CRV maint for ~22600 miles, likely found in the manual. :)
    AKBEAR63[QUOTED][OP] likes this.
  3. Jan 11, 2022 at 7:20 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    I don’t think so
    photogr4x4 and AKBEAR63[OP] like this.
  4. Jan 11, 2022 at 7:21 AM
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    I would ask them to see failed tests of brake fluid - 26,000 miles is crazy low for brake fluid to be bad enough (moisture level, copper ppm) to change unless there's a leak in your system or the reservoir cap has been taken off and left off frequently, and changing diff fluid at 26000 miles is ridiculous. Use in a truck most people won't do it 'till 40,-60,000 miles.
    Edit: Read up on the fuel induction cleaning - apparently those Honda engines run so clean, people don't bother until 90k miles.
    AKBEAR63[OP] likes this.
  5. Jan 11, 2022 at 8:04 AM
    AKBEAR63
    Bear
    2018 DCLB
    Thanks everyone...
  6. Jan 16, 2022 at 1:00 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Brake fluid degrades with time as well. How old is the CRV? Toyota's maintenance booklet says to replace it every 3 years.
    For diff fluid go by whatever the Honda maintenance booklet says.
