Servicing of a 2003 Tacoma transmission
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dadareno, Nov 7, 2016.
  1. Nov 7, 2016 at 8:34 PM
    Dadareno
    Dadareno [OP] Member
    2003 Tacoma
    In 09 I gave my dad a 2003 Tacoma. He says it has ran well for the past years, but recently has complained that he thinks the transmission is going out. Obvious question I asked him if he had gotten the transmission fluid serviced? His reply was that the transmission and the engine shared the same fluid so changing the engine oil services the transmission. This sounds crazy wrong to me, but I don't want to argue with him if he's right somehow. Can someone please set me straight?
    EDIT: If it matters for context, I live about 26 hours away from Dad, this conversation was all over the phone.
  2. Nov 7, 2016 at 8:54 PM
    toyrunner
    toyrunner Puddle Jumper
    Danny
    Pasadena, Ca.
    2004 4X4 Tacoma TRD Xtra Cab
    Kings in front, Bilstien Reservoir rears, Custom sway bar disconnects, 265/75 16 BFG AT's, ARB front bumper and FROR rear bumper. Bao-Feng 2 meter radio and Cobra CB
    Totally different systems and fluids. Early English cars shared fluids in a common case. nothing modern does afaik
    SnowroxKT and Dadareno[OP] like this.
  3. Nov 7, 2016 at 9:45 PM
    eon_blue
    Azusa, CA
    Um...yeah, your dad is wrong. The transmission and engine are two separate units. Both have their own respective (and different types) of fluid.
    Is it an auto trans or a manual? Manuals for these trucks take 75w90 gear oil. Automatics take ATF (automatic transmission fluid), Toyota makes their own brand I believe and it's recommended to use that.
    The engine takes engine oil, 5w30 standard unless it was switched to synthetic at some point.
    Dadareno[OP] likes this.
  4. Nov 7, 2016 at 9:57 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    My 1967 Mini Cooper s shares the same fluid as the trans and the engine
    My 01 Tacoma certainly does not
  5. Nov 7, 2016 at 10:05 PM
    Dadareno
    2003 Tacoma
    Thanks for giving serious answers. I'll talk with Dad tomorrow.
  6. Nov 7, 2016 at 10:10 PM
    Dadareno
    2003 Tacoma
    Manual transmission. He says he's changing the engine oil regularly. His statement on the transmission oil threw me. I just sort of stood there holding the phone, it sounded so wrong, and yet he sounded so sure of himself and I didn't know absolutely for sure.
  7. Nov 7, 2016 at 10:14 PM
    eon_blue
    Azusa, CA
    Well, in your dad's defense (and I wasn't aware of this myself), it sounds like on some much older vehicles the engine and transmissions DID in fact share the same fluid, so it's not that far fetched for him to assume that.
    The good news is, the manual transmission is a very simple and strong design (compared to the auto) and it's tough as nails...you'd have to try pretty hard to 'ruin' it. It would definitely be a good idea to drain/fill the fluid ASAP if it's not acting normally and hasn't been serviced in a long time.
    There are a few highly recommended brands out there, Redline 75w90 is probably the most popular as it seems to help smooth out harsh shifting. Royal Purple and Valvoline are also reputable brands.
    Dadareno[QUOTED][OP] likes this.
  8. Nov 7, 2016 at 10:19 PM
    eon_blue
    Azusa, CA
    Also, it's really easy to do yourself. I don't have a garage or much mechanical experience at all but I can change out the fluid in my manual trans myself in under 20 minutes. Make sure the truck is on a level surface. You have a fill plug and a drain plug on the trans. Crawl under the truck and loosen the fill plug first (so you know for sure that you can fill it after it's drained), then loosen the drain plug and let the old gear oil drain out. It's recommended to use new crush washers for the fill/drain plugs when you put them back on, they're like 10 cents each from Toyota or Amazon.
    Tighten the drain plug back on, then fill the transmission up through the fill port until you see fluid start to drip out. That's when you know it's full. Put a new crush washer on the bolt, tighten it up and you're good to go.
  9. Nov 7, 2016 at 10:27 PM
    eon_blue
    Azusa, CA
    Actually I assumed your truck was a 6 lug (4x4), if its a 5 lug 2wd be sure to check the manual to see what kind of weight the gear oil needs to be for the transmission, it might not be 75w90 like the 6 luggers use
  10. Nov 7, 2016 at 10:29 PM
    Dadareno
    2003 Tacoma
    Some 35-40 years ago Dad did work on cars to some degree, so maybe this is where the idea came from.
    If it hasn't been changed since 08 or 09, I'd estimate he's put 80-90k on the truck since then. Pretty impressive if the fluid really hasn't been changed since then.
    eon_blue[QUOTED] likes this.
  11. Nov 7, 2016 at 10:32 PM
    Dadareno
    2003 Tacoma
    It is the 6 lug, which reminds me that I should suggest that he also get the 4x4 serviced if he hasn't done that.
  12. Nov 7, 2016 at 10:35 PM
    eon_blue
    Azusa, CA
    Yeah the manual says to do it every 30k miles so it's definitely overdue. As far as the 4x4 system goes, the front differential has the same service interval if I'm not mistaken so it's likely overdue as well (but less likely to be as worn if he doesn't use 4wd often). The manual recommends using 4wd once per month to keep everything lubricated and working properly (10 miles or so), so finding a dirt road or someplace safe to use 4wd every so often is good to do as well.
    Same goes for the rear differential and the transfer case, they all take respective gear oil and they're all fairly easy to DIY, so it's probably a good idea to do it all at once if they haven't been done in awhile.
  13. Nov 8, 2016 at 5:04 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    In the 2nd gen thread I just remarked that my boss has 438K miles on all his original fluids. Yes including coolant. He says he's added coolant, never changed it. That's an 05 6-spd 4x4. Oh, I'm lying, he had a clutch done at 230 or so K. I'm sure they changed the trans. gear oil then.
    Don't sweat it man, manual trans. can take a beating as long as thy have oil in them.
  14. Nov 8, 2016 at 9:02 AM
    Dadareno
    2003 Tacoma
    Toyota's new ad campaign:
    Toyota Tacoma - Truck for the maintenance
    adverse
  15. Nov 8, 2016 at 1:39 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I'd never rec'd it of course....in fact I'm kind of a stickler for PM BUT there's prob. just as many trans. get bad synchro's that have had it done every 30K as people who just changed it with the clutch.
  16. Nov 8, 2016 at 5:02 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    The power steering and auto trans are the same.
    If it's an auto trans. You can disconnect the hose clamps at the radiator. Get longer lengths of tubing. Put a funnel in the trans dipstick tube. Get drain pan. Start it up and drain out some. Shut it off. Fill it up the same that came out. Start it again and repeat.
  17. Nov 9, 2016 at 10:45 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    What symptoms is he having with it? Maybe the transmission is fine but the clutch is wearing out.
