Servicing the Front Differential 1996
Discussion in 'Technical Chat' started by Woodcutter, Dec 21, 2013.
  1. Dec 21, 2013 at 10:29 PM
    Woodcutter
    Woodcutter [OP] Well-Known Member
    St. Petersburg Florida
    96 Taco 4 x 4 SR5
    Please advise on how to drain the front differential. Oh, an FYI - the 24 mm crush washer on the drain plug is part # is 12157-10010. Be sure to install it with the flat side toward the nut so that the raised side is facing toward the open part of the bolt and will interface directly with the housing when you snug it down. Thanks, See vid on tip that may help with drain plug problem. http://www.youtube.com/watch?v=GIbb7XfYiHE Woodcutter
  2. Dec 22, 2013 at 10:03 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Hmm might do this mod now because my bots are stripped
