Set button on 2007 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FF02, Feb 20, 2007.
  1. Feb 20, 2007 at 2:03 PM
    FF02
    FF02 [OP] Member
    Hello all,
    I am new to this site and so far its been really helpfull. I have had three tacomas and I just purchased a 2007 4x4 4dr tacoma. Recently I changed the oil and before I knew how to reset the maint reqd I found this SET BUTTON. It is located under the steering wheel next to the hood release latch, on the right side. Does anyone know what this is and what it does?
  2. Feb 20, 2007 at 2:16 PM
    ducatista
    ducatista Active Member
    CAPTAIN CRAZY
    DALLAS TX & CLARKSDALE, MISSISSIPPI "THE CROSSROAD
    TACOMA X-SP
    EVERYTHING THAT I CAN AFFORD ! ESPECIALLY IF IT MAKES IT RUN BETTER &/or FASTER, STOP QUICKER AS WELL AS LOOKING GOOD @ THE SAME TIME.
    Is it the Tire Pressure Monitoring System ?
    OWAF
    Andy
    Lots of toys
  3. Feb 20, 2007 at 3:37 PM
    FF02
    FF02 [OP] Member
    oh, ok have you used it?
    When would one have to use it?
  4. Feb 20, 2007 at 4:52 PM
    spp
    spp OC, Kalifornia
    OC California
    Not to be a smart ass but it is far easier to look it up in your owners manual than to type out the page for you here.:)
  5. Feb 20, 2007 at 4:56 PM
    FF02
    FF02 [OP] Member
    I know, i am going to do that. At least i know what it is and where to look now.
    Thanks!
  6. May 16, 2007 at 5:28 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    so what was the button for
  7. May 16, 2007 at 6:06 PM
    flyman767
    flyman767 Well-Known Member
    It's the TPMS(tire pressure monitor system) reset. When a tire pressure is low it will light 'steady' identifying an under/over inflated tire. Check all tires(incl spare) and add or remove air from tire(s). Pushing set bottom will extinguish light. However, if the light is 'blinking' this identifies a TPMS malfunction and you will need to take it to the dealer.
