Set me straight on the whole lift thing...
Discussion in 'Suspension' started by GearBox, Sep 12, 2010.
  1. Sep 12, 2010 at 9:40 PM
    GearBox
    GearBox [OP] I hate Commie Libs!
    Gear
    Phoenix
    07 Tacoma Double Cab TRD Sport 4x4
    I know you guys have probably answered this a million times, but I have been reading all of your guys' build and trying to put together my own build list and I want to make sure that I am going in the right direction.
    First off my truck is a daily driver. I want to lift it and put 265/75/16 of tire on new 16 inch rims. So please correct me if I am wrong. To level/lift my truck I need:
    -5100s front and rear set to 2.5 inch on the front and use my stock springs.
    -2 inch AAL in the rear
    Do I need anything else? If its not needed is there something else that you guys recommend for the general health of my Taco? :) (UCA's, Diff Drop, etc..)
    As far as my truck being a daily driver this will not be too extreme right? I want to keep the stock ride/handling if not improve it. Thanks in advance for all your help. You guys rock!
  2. Sep 12, 2010 at 9:44 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    this is a good start. You really dont NEED anything else, but to get your alignment perfect you need UCAS. I have a 2.5ish lift and I dont have them but my alignment is pretty god darn good. So I would go with what you have selected.
  3. Sep 12, 2010 at 9:44 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    search?
  4. Sep 12, 2010 at 9:46 PM
    Andy2010
    Andy2010 Well-Known Member
    Andy
    Bucks County, Pa
    2010 TRD Sport Mag Grey 4x4
    EGR inline vent visors, Trimmed front mud flaps, Hose clamp mod, AFE Pro-Dry S air filter, Bed mat off my '97, 5100's up front @1.75, Rear TSB, Tow package, Black TRD center caps, Weathertech Digitals, Wet Okole's in front
    You've got it about right. Prob need UCA's. Do a search, TONS of stuff on this
  5. Sep 12, 2010 at 9:55 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Idk about the 2" rear maybe 1.5" would be good enough.
    For the rear your going to need axle shims and a carrier bearing drop!
    And you most likely, well almost positivly, wont need UCA's unless you want the looks and the extra ~1/2" of articulation!
  6. Sep 12, 2010 at 9:57 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    x2 on the 1.5" AAL
  7. Sep 12, 2010 at 10:38 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    FYI , you don't need to lift your truck to run 265/75/16 .
  8. Sep 13, 2010 at 3:53 AM
    Derpy Derek
    Derpy Derek Well-Known Member
    Derek
    Brookings, OR
    2012 TRD Sport 4x4 DCSB
    ARB Bumper, Smittybilt X20, King suspension
    I was about to make a post asking the same thing, but instead of the 2 inch aal in the rear, what if I got a 1.5 in aal in the rear + the tsb for the extra height and free alignment?
  9. Sep 14, 2010 at 2:14 PM
    GearBox
    Gear
    Phoenix
    Yeah I understand that part. Will it look weird with 265's? I was wondering if there would be too much space in between the tire and the truck but I have seen other peoples rigs and it looks pretty good to me.
  10. Sep 14, 2010 at 2:18 PM
    08pretaco
    az
    I dont think that if you brought your truck in with an AAL that they would give you the TSB and a FREE alignment. I know the alignment really doesnt do much for the truck since they do a front wheel but still.
    Some dealership play ball some suck balls
  11. Sep 14, 2010 at 10:18 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Nah, keep it simple.
    265/75R16, Bilsteins set at 1.8 (no UCAs or diff drop needed at that height!) 1.5" AAL in back - shouldn't need spacer or shims at that level of lift either.
    You'll probably need to remove the front fenders.
    Done. And no, that won't look weird - it'll look about right, IMO.
  12. Sep 14, 2010 at 10:20 PM
    OZ-T
    Peter North
    British Columbia
    As I said above , you can run 265/75/16 on a stock suspension . If you lift it for looks , fine , but there is no need to remove the fenders .
  13. Sep 14, 2010 at 10:24 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    i have the 5100's at 2.5 with 265/75's with stock uca's and the toyota aal TSB.
    it looks right. i use it as my DD and i have a couple rub spots on my UCA's, LCA's and little on the frame. but thats probably because i have such bad camber :laugh:
    you should be good man :thumbsup:
  14. Sep 15, 2010 at 10:19 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Some have had to remove mudflaps in order to fit 265/75R16.
  15. Sep 15, 2010 at 10:19 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Remove fenders?
  16. Sep 15, 2010 at 10:23 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Guffaw! Corrected.
  17. Sep 15, 2010 at 11:42 AM
    GearBox
    Gear
    Phoenix
    Awesome! Thanks to all of you guys. I will go ahead a get that stuff rolling when my bonus comes in and I will throw up some before and after pics :D Once again thanks for the help.
  18. Sep 15, 2010 at 12:05 PM
    JTO
    JTO Well-Known Member
    San Diego
    PreRunner Sport
    This is the route I was planning on going as well. If you don't have the rear tab done do you go with a 2" AAL or stick with the 1.5"?
