Setting for 5100 + OME 884
Discussion in 'Suspension' started by oneshot808, Nov 29, 2011.
  1. Nov 29, 2011 at 8:47 AM
    oneshot808
    oneshot808 [OP] Well-Known Member
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    Wet Okoles/Weather tech all around, LED's +HIDS, 6"Fabtech w/ Fox front & rear
    I have them set at the 1.75. I believe my question is what is the ideal setting that everyone has?
    set the 5100 at 0? or the highest notch.?
    I read in the other thread ideal is 0 since the OME884 compensate ? please help im taking them apart wed morning to reset it. i'll take a pic later.
    I'm adding a AAL Fabtech 220 in the rear. while im doing the resetting the front.
    I do not have rear 5100's yet I have them coming in soon .
  2. Nov 29, 2011 at 8:48 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    i can't help with the 884's but i have mine 5100's set on .85 with eibach springs w/ toytec AAL and i think it sits pretty damn level
  3. Nov 29, 2011 at 8:59 AM
    RecklessTaco
    RecklessTaco Livin the Dream
    Topaz Lake, Nv.
    08 Dbl Cab Prerunner TRD Sport Debadged
    ENGAGE LT KIT, King 2.5x 8" coilovers w/600lb 18"coil springs, a custom built leaf pack in the rear by OMD, and a custom built prerunner bumper by SurfInferno. 35x12.50-17General Grabbers on 17x9 Black MB Wheels rims, Volant CAI w/Amsoil dry filter, Volant Ram Air, Poweraid Throttle body spacer, URD MAF Calibrator, Flowmaster40, Uniden Bearcat cb w/ 4' fire fly firestick antenna, & a Icom V80 Handheld(Modded for race channels)
    5100's and Old man emu 884 coils should only be set at the lowest setting which is 0. The lowest ring setting!
    Setting them at 1.75 preloads the 884 coil to much and you could cause serious damage to suspension componets.
  4. Nov 29, 2011 at 9:09 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You can set the 5100s at .85 with 884s without doing any damage although you're better off just getting 885s.
  5. Nov 29, 2011 at 11:19 AM
    oneshot808
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    so general opinion is leaning towards resetting it to 0 and letting the OME884 due its work. Im planning on adding a fabtech 202 aal to the rear with stock bilstein rear shocks.
  6. Nov 29, 2011 at 11:29 AM
    Pugga
    Massachusetts
    You can set the 884's at the .85 setting, they are shorter than the other OME coils so they won't do any damage by doing this. Ideally though, if you want the extra lift, you should just get the 885 coils since they have the same spring rate but are taller. This would also give you a better ride since you won't be preloading the coil as you would be with 884's at .85.
  7. Nov 29, 2011 at 11:41 AM
    oneshot808
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    well i have the 884's already and i don't think the wifey is gonna let me get the 885 anytime soon.
    06taco4.0 likes this.
  8. Nov 29, 2011 at 12:18 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I can set you up with a good aal for how you use your truck.
  9. Nov 29, 2011 at 5:09 PM
    oneshot808
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    Oh i have a aal ft202 already just havne't installed it. was gonna try and order the rear 5100 from someone.... do you guys carry?
  10. Nov 30, 2011 at 5:15 PM
    oneshot808
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    never mind it ended up lvl great . now i just gotta pick up a rear set of 5100
  11. Nov 30, 2011 at 8:50 PM
    Fletcher007
    Fletcher007 Well-Known Member
    Fletch
    Phoenix,AZ
    17 Access cab 4x4 4cyl 5spd Magnetic Grey
    Fox 2.0 coilers, Fox 2.0 rear shocks, 17" 4Runner Trail Edition 7 spoke rims, 255/75 17 Yokohama All Terrains. Secondary air filter removed and AFE pro Dry S installed. Lower Air valance removed. Secondary smog pump mod done. Cali Raised ditch lights and amber fog lights installed with On off switches installed in 2 of 3 factory blank slots!
    i have the 885's with 5100's and am headed in on friday to have them bumped to the first notch .85. i called downsouth and they said it shouldnt be a problem...fyi
  12. Jan 17, 2012 at 7:42 AM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    thread revival...so do you guys sit level w/o an AAL with the OME 884 or 885 coils? I want coils to replace the use of the 5100's to lift, but the Eibachs are back ordered so i'm thinkin OME...
  13. Jan 17, 2012 at 8:17 AM
    Pugga
    Massachusetts
    884's will give you around 2" of lift on a double cab, 885's will put you around 2.5". You'd probably be a lot closer to level with 884's if not a tad nose high depending on whether or not you have TSB springs or not.
  14. Jan 17, 2012 at 9:53 AM
    Large
    Large Red
    OME 885x w/5100 @ "0"
    2" AAL (no TSB)
  15. Jan 17, 2012 at 11:31 AM
    TacomaGus
    Gus
    Morgantown, WV
    do not have the TSB done, so the 884's seem to be perfect. I am going to email toytec and wheelers w/ the same question to confirm...
  16. Jan 29, 2012 at 7:28 AM
    ComaChic
    ComaChic Well-Known Member
    New York...not the city!
    06 DCLB TRD Sport V6
    OME 885's w/ Top spacer kit, OME Nitro 90000 Sport and N182, LR UCA's, 2" AAL non TSB, Window tint, K&N Intake, Lights
    Hey what sire tires are those. An minor trimming?
  17. Apr 10, 2012 at 8:48 AM
    trktwo
    trktwo Nagger
    tommy
    biloxi
    2015 MGM DCLB TRD Sport 4x4
    i also see u are using tc uca. does that provide any additional lift? i have 5100s on stock springs at 1.75. i'd like just a little bit more lift, like .5 inch.
  18. Apr 10, 2012 at 9:53 AM
    stattonmw
    stattonmw Well-Known Member
    Statton
    Redmond, WA
    2014 DCLB Tacoma TRDsport
    5" RCD Lift TOYO ATII Extreame 295/70R18 XD Addict wheels Factory toyota side steps TRD exhaust
    If possible really curious what your measurment from center hub to fender is... Any issues?
