Setting up 2007 Tacoma Pre-runner to flat tow behind RV.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by genesr, Apr 8, 2017.
  1. Apr 8, 2017 at 2:00 PM
    genesr
    genesr [OP] New Member
    Gene
    2007 Tacoma Pre-runner SR
    Has anybody set up their Tacoma to flat tow behind an RV? So far I have installed (had installed) the tow bar base plates. A neighbor gave me a tow bar. I have purchased a Roadmaster Invisibrake system for braking and have also sourced a de-coupler drive shaft. Does anyone know what, if any, other things need to be done to before towing (like fuse removal, etc.)? Thanks.
  2. Apr 8, 2017 at 6:06 PM
    Mongoose
    Mongoose Well-Known Member
    Catskill Mts. NY
    Don't think you need to remove any fuses. You will have to wire some tail lights. My dad tows his, ( has very a similar setup to yours ) and added an extra 1157 socket and bulb into the OEM tail lamps for that purpose.
  3. Apr 8, 2017 at 6:23 PM
    schleygo
    schleygo Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    Only thing I can think is make sure tires are aired up to the what the tire manufacturer's limit is. We towed a single cab from Dallas to South Padre and learned the hard way. On the way down, they were aired at 33PSI. Back home, 50PSI. Gained 2-3mpg on the way back in our tiny experiment. I know I know....so many variables
    Nothing else to really do that isn't obvious.....
  4. Jan 5, 2018 at 2:32 PM
    KixRock
    KixRock Member
    Kix
    2009 Tacoma Double cab V6
    I'm in the beginning stages of setting up an 09 Pre Runner dbl cab 6 cyl RWD with AT. How do you handle steering wheel lock? Have you found and other "challenges" in getting your 07 set up? Thanks Kix
