Setting Up ARB Compressor/Locker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Camel51, Sep 24, 2016.
  1. Sep 24, 2016 at 6:04 AM
    Camel51
    Camel51 [OP] Well-Known Member
    Colorado
    2006 DCSB TRD-Offroad
    OME BP51's, Brute Force Fab
    I'm getting an SPOD soon and setting up custom switches with OTRATTW. I'm new to electrical and have very limited experience with the ARB locker on a buddies truck.
    First thing: I believe my buddy had it setup where the compressor needs to be activated first then you can engage the rear air locker. Then you turn the compressor off to disengage. Is this true all of the time? (I can't get in contact with him anymore to ask him).
    If so can I use this switch to do both in one?
    http://www.otrattw.net/V-SERIES-SEALED-ROCKER-SWITCH-BODY-ONLY-NO-ROCKER-VMD2UXXB-00000-000.html
    It is a DPDT OFF/1.ON/2.ON (MOMENTARY) switch. Can I use this to 1. Use the compressor alone to air up my tires 2. Activate the compressor and engage the locker?
  2. Sep 24, 2016 at 6:08 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    You will need to turn on the compressor first. Every time, and leave it on.
    Then flip the locker switch. Leave the compressor on as you have the locker engaged.
    Camel51[OP] likes this.
