Setting up Shocks
Discussion in 'Long Travel Suspension' started by flesh2, Feb 16, 2012.
  1. Feb 16, 2012 at 4:46 PM
    flesh2
    flesh2 [OP] Well-Known Member
    08 DB Cab long bed
    TC Lt, Dmz kit, Hnm bedcage
    I have 08 tacoma with TC LT running coilover with 500lb spring. Problem is that its to soft, so do I change the spring rate or shock valving? :/
  2. Feb 16, 2012 at 4:49 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    prolly both. 500# springs are too soft for an 08 D-cab, and chances are you're valving isn't as good as it could be
  3. Feb 16, 2012 at 4:53 PM
    flesh2
    08 DB Cab long bed
    alright yea shocks are valved to what TC sends out , would 600s be to big of a jump?
  4. Feb 16, 2012 at 4:55 PM
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    LT, Kings, Fabricated Trucks Worldwide For The Win, K&N and Doug Thorley LT Headers
    Lets trade springs!!
    I have 600 lb springs and I've been wanting 500 lb springs!!
    Mine are King 18" long..
    PM me if you are interested..cus I sure as hell am!!
  5. Feb 16, 2012 at 10:58 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Escondido, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    600# with a re-valve of the compression would help a very large amount. How far down do you have the coils cranked to stay at ride height?
  6. Feb 16, 2012 at 11:02 PM
    flesh2
    08 DB Cab long bed
    I think about 2 , 2.5 inches
  7. Feb 16, 2012 at 11:29 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    I think 600 would be good for a double cab 08. 550 if you want a plusher ride.
  8. Feb 17, 2012 at 7:04 AM
    flesh2
    08 DB Cab long bed
    Would adding bypasses later on change the spring or just the valving of the coilover?
  9. Feb 17, 2012 at 8:45 AM
    noSKills858
    Alex
    Escondido, CA
    No you still need the coil to support the truck weight.
  10. Feb 17, 2012 at 8:48 AM
    flesh2
    08 DB Cab long bed
    Alright thnks
  11. Feb 17, 2012 at 10:06 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    are you 2wd or 4wd?
  12. Feb 17, 2012 at 10:07 AM
    flesh2
    08 DB Cab long bed
  13. Feb 17, 2012 at 10:10 AM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    I would honestly trade springs with BMiller421 , its also easier than buying and selling. Then after you should get them revalved which is about $70-110 for both shocks. Both these things should see a far greater improvement.
  14. Feb 17, 2012 at 11:49 AM
    Marnes2986
    Marnes2986 Well-Known Member
    Mark
    Anaheim-Corona, Ca
    Springs/coils are mostly used for ride height, dependent on weight as well. People really shouldnt be basing suspension ride with coils, thats what shock valving is used for. But a lot of people do including myself. Like previously stated...
    500# 18" will be good if youll be running lift spindles. Its the standard to use when you get them, because it will allow you to take off enough preload and give decent ride height.
    Ive got 550# with no spindle and my coilovers are cranked up high. I will be getting spindles soon, so I should be ok.
    I say, if your 4wd or not going to get spindles. Grab some 600# springs. If you add a bypass and the ride is too stiff, thats what shock valving is used for. Valve the shim stack to have less damping. Or open the Comp tubes wideopen.
    If you thnk youll get some lift spindles, grab some 550# and put some compression damping in your bypass like what i did.
  15. Feb 18, 2012 at 8:27 AM
    flesh2
    08 DB Cab long bed
    Sounds good , marnes- do you know what valving comes in the fox coilovers with the TC kit?
  16. Feb 18, 2012 at 9:25 AM
    Marnes2986
    Mark
    Anaheim-Corona, Ca
    Im not sure.....do the fox shocks from TC come prevalved for our truck specification?
    I know if you look eiter on the shock cap or somewhere on the body there should be numbers that correspond to a valving chart on Fox. When you find the numbers and look it up on Fox's chart you can see what valving you have.
    Link to the valving chart: http://www.foxracingshox.com/dl/offroad/foxrs-or-bypass-s.pdf
  17. Feb 18, 2012 at 3:15 PM
    flesh2
    08 DB Cab long bed
    Alright sweet thnk , yea I thought they come valves for the kit but I could be wrong. I'll look at the shocks tho and try and find the number
  18. Feb 20, 2012 at 6:41 PM
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    I still want to trade springs if you are up to it
