Setting up Torque Pro for transmission temps and TC lock
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JimLS, Jul 7, 2024.
  1. Jul 7, 2024 at 2:33 PM
    JimLS
    JimLS [OP] Well-Known Member
    Got Torque Pro and have it linked to the vehicle and showing default gauges. That was easy. Found some numbers for trans temps here which mostly match some posting on this site but not working. There is a note of some change in 2021 and I have a 2023 (V6 SR5 if that matters). Tried to sign up on the torque forum but for some reason never got the confirmation email to set up the account - tried twice with different emails. Will try again later. Anyone got the numbers I need?
    Here's the site I was looking at for numbers that didn't work but maybe I was doing something wrong.
    https://obd2australia.com.au/obd2-pids/
  2. Jul 7, 2024 at 5:03 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Well, I'll get this started, perhaps someone with some actual knowledge will join in. The link you supplied is probably for Australian vehicles and may not correspond to USA vehicles. Some may, some may not.
    Last I heard Australia does not have the Tacoma, I believe they have the Hilux.
  3. Jul 7, 2024 at 5:45 PM
    JimLS
    I would welcome some better references. I have a coworker that uses Torque that can probably give me some good tips. Not a Tacoma driver but should be able to point me to some good documentation.
  4. Jul 7, 2024 at 6:07 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
  5. Jul 10, 2024 at 9:00 PM
    JohnDeere630
    JohnDeere630 Well-Known Member
    Gary
    Gray 2023 Tacoma SR5
    Those numbers you have won't work. Here is the list I use:
