Settle an argument for me.
Discussion in 'General Automotive' started by TacomaPrime, Jun 20, 2012.
  1. Jun 20, 2012 at 12:25 PM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    The wife says that it's bad to leave your AC on in your car, cause then when you go to start the car, the AC compressor will be on, and it's bad for the car. Or something along those lines. Basically, everytime she turns her car off, if the AC is on, she will shut it off before turning the car off.
    I never do that. I leave it on all the time, until I don't want to use it anymore. I've never had it do any damage to any vehicle I have ever owned. that I know of anyway.
    So what say ye. :confused:
  2. Jun 20, 2012 at 12:27 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    might have mattered back in the 70s but not anymore.
  3. Jun 20, 2012 at 12:27 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    if you hadn't learned by now your wife is always right...
    that said she is actually right this time.. also turn off the heat.
  4. Jun 20, 2012 at 12:28 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Tell her to worry about the appliances, you'll worry about the vehicles :D
    I take no responsibility if she beats your ass sensless as a result...
    On a serious note, I've never heard that leaving the A/C on when you turn the vehicle off would cause damage. It might make for a slightly harder start because the compressor will be running right off the bat but other than that I can't see how it would do anything negative.
  5. Jun 20, 2012 at 12:29 PM
    dpak
    dpak Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Toytec/Eibach coils w/ 5100's set at 0, Toytec 2.0 Aluma Rear Shocks, Toytec Boss Leaf Springs, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, Elusive Elements Mesh Grill
    I do the same thing your wife does. I always turn off the ac either before I turn off the car or after it's turned off. Don't know if its good or bad for the car though. To me, its just one less thing the car has to turn on before starting up the car.
  6. Jun 20, 2012 at 12:32 PM
    IndigoTac07
    IndigoTac07 Tortoise*
    AJ
    Houston
    '07 Tacoma
    I agree with Pugga, I think I read that somewhere.
  7. Jun 20, 2012 at 12:32 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    The compressor is not on when you first crank your car, regardless where the switch is, the fan yes, but so what?
  8. Jun 20, 2012 at 1:07 PM
    tinker_troy
    T R O Y
    WY/SD
  9. Jun 20, 2012 at 1:11 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    You are listening to your wife's car advice? What does she do with the AC while she is in the kitchen?
  10. Jun 20, 2012 at 1:18 PM
    LMR
    LMR GO JETS GO
    Lee
    In The True North
    2008 Tacoma DCSB TRD
    Shorty antenna, Weathertech digital fit, tonneau cover
    1. disagree (even though you really don't care either way)
    2. get in argument
    3. apologize
    4. have make up sex
  11. Jun 20, 2012 at 1:20 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    This
  12. Jun 20, 2012 at 1:25 PM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    Why is her car in your kitchen? Why does she need a car when she doesn't leave the kitchen?
    It doesn't matter. The ignition switch/PCM/BCM kills all electrical accessories when put in the start position.
  13. Jun 20, 2012 at 1:28 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Cough* Ban *cough*
    I dated a girl who would shut my AC off before I turned the truck off for this reason. And she got told to not touch anything except the radio when I deem it necessary to do so.
  14. Jun 20, 2012 at 1:29 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    I don't think it hurts the compressor or any other mechanical parts of it but I DO know that keeping it on when you shut off the engine is not a good idea.
    Why, you ask?
    Because when you are running the air, there is moisture accumulating in the cabin filter and the housing. When you shut off the air, the moisture stays. Sometimes it does not evaporate thoroughly. Funk appears, mold grows and that is why you will sometimes get a weird undesireable smell when you first turn it on. It's not good for you to breath all that funk.
    What is suggested, is about a minute before you turn the engine off, shut off the AC but keep the fan on high. That shoots out whatever "cold" is left in the system, gets a little warm air into the filter and lets it dry out a little, not allowing mold to grow. The longer you leave the fan on and the AC off the better.
  15. Jun 20, 2012 at 1:29 PM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    Rule One : She is never wrong
    Rule Two: If she is wrong refer to rule one.
    I turn mine off out of habit, there would be a heavier draw on the battery but other then that nothing to worry over .. That is of course as long as your battery is good...
    There is an old joke . Man and a woman get married on thier wedding night after spending several hours consumating the wedding the man gets out of bed. He picks up his pants and turns to his new bride and says " honey here I want you to put these on" she laughs and tells him no. He persists telling her honey for me please " get up and get into these" she laughs at him again saying "no I can't get into them they are to big". He says right and remember that I wear the pants. She looks at him and gets up out of bed walking over she picks up her panties. Turning to him she holds them out and says " here put these on" he is like honey I can't they won't fit. Again she tells him please for me put these on he responds " honey no I can't get into them" . She says right and you won't get into them again unless you change that attitude.....
    Now ask your self is it worth the arguement ? Just Saying LOL
    Cypher
  16. Jun 20, 2012 at 2:24 PM
    Tacoma Mike
    Southern Maine
    This........ Perfect answer.....
  17. Jun 20, 2012 at 2:27 PM
    babytruck
    NorCal
    Thank you Mr. Toyota Tech. :)
    Not bad for a girl, huh? :p
  18. Jun 20, 2012 at 2:31 PM
    IndigoTac07
    AJ
    Houston
    '07 Tacoma
  19. Jun 20, 2012 at 2:39 PM
    t4daddy
    North Alabama
  20. Jun 20, 2012 at 2:40 PM
    Pugga
    Massachusetts
    If this were the OP's argument, I could at least see the reasoning behind it.
