Setup Help - 2023 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by djmathews, Jul 4, 2023.
  1. Jul 4, 2023 at 6:34 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I assume you’re talking about lift height.
    With the 5100’s on stock springs on the 5th perch, I’m at approximately 2” of lift. I haven’t measured it exactly, but I used to have a 2” spacer lift which was a 2” slab of metal and this setup gives me about the same ride height. So I didn’t feel a need to measure it.
    That’s just in the front because the 5100’s don’t add any lift in the rear. I can tell you that I fit 33”s with no rubbing on the road. No chance 34’s or 35’s would fit without a whole bunch of work though.
    Those look cool and all but unless you’re planning on doing actual rock crawling, you probably never need anything more than a 33” tire. Like I said in my earlier post, my 32’s don’t look super cool but they’ve literally taken me on trails and beaches of all sorts, all over the country, with zero issues.
    LeakyAC and Junkhead like this.
  2. Jul 4, 2023 at 7:23 PM
    djmathews
    djmathews [OP] Member
    Dave
    2023 White Tacoma TRD Offroad
    Doubtful… I’m saying this based on how they are “advertised as” compared to how much true Hub to fender clearance happens. For instance I am taking manufacturers now comparing numbers. 2” lift real world ended up with 1 5/8ths lift center hub to fender or less.
    Based on my mock up I need 2 3/4 - 3 hub to fender to clear without any major rubbing with offset correction. So I’ll look into these 3-3.5 lifts and hopefully somewhere someone posted hub to fender numbers. All the lifts 4 are just overkill with new cross members and the works. I don’t need that and will play with tire size before jacking up the frame.
  3. Jul 4, 2023 at 7:40 PM
    djmathews
    Dave
    I’ve had plenty of nice 31s and 32s get me where I needed to go on smaller rigs. Usually plenty for the snow and mud. It really all boils down to weight and footprint. I’m sure I could handle the mud and snow fine on smaller, it’s the dunes here that would be the challenge. Very loose very dry sand that needs that big footprint. But it’s too much fun to not try and do it right.
    Worst case I could try a set of paddle tires I’ve seen some tacomas with it but that’s ment for higher HP and would put strain on everything. Had good luck with fat tires on light vehicles floating right over the sand there. All the full size trucks are running 38s or bigger just to not sink in.
    Road_Warrior[QUOTED] likes this.
  4. Jul 4, 2023 at 7:42 PM
    SagWagon
    SagWagon Well-Known Member
    Geoff
    Portland, OR
    2022 TRD OR
    Why do you think you need a diff drop?
    https://youtu.be/47aat1tc6zw
    Also, if you’re planning on spending money on an AAL, just send the money to me. That way you don’t have to try sell it later when you buy new spring packs.
    I’m sensing askhole, but I’m trying to give you the benefit of the doubt and assuming Dunning-Krueger is at play.
    AmateurTaco1313 and OZ TRD like this.
  5. Jul 4, 2023 at 7:51 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I did 2.5 lift, 275 17 pro rims, 2" cheap add a spring and wildpeaks. Can clear anything and go anywhere. Two years in and wouldn't change a thing. Get a ton of compliments and offers to buy.
    Junkhead and djmathews[OP] like this.
  6. Jul 4, 2023 at 8:11 PM
    djmathews
    Dave
    I learned my lessons with IFS going beyond a 2.5 lift in the past not dropping the diff. I mean they worked sure but I burned up CVs and even a third member before. Every single kit I see comes with the diff drop so I assumed tacomas had the same issues if not I’m all ears. I’d rather not move it if it can handle the angle… exactly why I’m asking which route to go.
    As for the rear I’m seeing the same complaints of bad angles and seals 2 inches and up with springs, blocks, or AAL… More relocation brackets instead of fixing the angle. So again if someone has a nice spring pack that will get me 2-2.5 at the proper angle I can do that too. I like OME but seeing reviews that they are sagging after a year or so… again all ears that’s the point of asking
  7. Jul 4, 2023 at 8:21 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    FYI, if you planning to cycle your suspension, a lift won’t help you clear wider/larger tires. With Toyota IFS, you are just changing the starting point, your wheel will still travel through the same range of motion as it did stock. You just end up with more uptravel and less downtravel.
    My OME 2” lift settled at 1 3/4” with steel sliders, aluminum stump bumper + winch and TRD skid plate. I’m a happy camper.
    Watch these videos and you will fully understand what I mean:
    https://youtu.be/LAYGdcKSA3o
    https://youtu.be/_68Hc8GtLko
    This guy is fantastic!
    djmathews[QUOTED][OP] likes this.
  8. Jul 4, 2023 at 8:23 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    My rear leafs gave me just over 2” of lift, had to install 4 degree shim under the axle to correct minor driveline vibrations. Smooth as butter now.
  9. Jul 5, 2023 at 9:00 AM
    djmathews
    Dave
    Sounds perfect! I noticed guys mentioning shims or using angled blocks so I assumed it screwed it up a bit. Both are cheap fixes so I’ll toss a couple in the cart with the springs to be safe. What brand springs did you get?
    after looking at everyone’s struggle I think I’ll just splurge for the adjustable coil overs and adjustable UCA so I have as much room to play with correcting for the larger tires and change to suspension location on the fronts.
    Junkhead[QUOTED] likes this.
  10. Jul 5, 2023 at 9:35 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I’m running dobinsons medium leafs.
  11. Jul 5, 2023 at 9:48 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Ironman Foam Cell Pro. Heavy springs front and rear. I'm able to clear 34" tires with just under 11" cross section without any cutting or rubbing. Its all about the alignment.
  12. Jul 5, 2023 at 9:51 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Did you cycle your front suspension?
  13. Jul 5, 2023 at 9:54 AM
    airforceb2cc
    Don
    KCMO
    Oh yes...many times. Gets close to the cab mount and flare in the back due to the caster but luckily the limited wheels have such a positive offset, I'm closer to the UCA than I am the cab mount. And if the tires have mud on them or are at full pressure, I will rub the top of the liner at full stuff. Air down to 13 on the trails and I'm golden.
  14. Jul 5, 2023 at 10:43 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Nice man!
    What is the exact size of tires you are running?
  15. Jul 5, 2023 at 10:59 AM
    #35
    airforceb2cc
    Don
    KCMO
    275/70R18 - Treadwright Wardens. Math says they are 33.2" but measure out new right at 34" at 32PSI. Drop down to about 33" at 13PSI.
