SG2 codes
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2KTacoPr3runn3r, Dec 26, 2010.
  1. Dec 26, 2010 at 3:46 PM
    2KTacoPr3runn3r
    2KTacoPr3runn3r [OP] Well-Known Member
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    Bilstein 5100 adjustables, 2 inch top plate spacer, bilstein 5100 rears and 2 inch blocks. Flowmaster super 10 with dual 4 inch tips.
    just got my scangauge2 set up. i was wondering if there were any other useful codes for the first gen's. ive got the tranny temp and horsepower already. tried altitude but it didnt work. anybody got any others?
  2. Dec 26, 2010 at 7:05 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    I don't have a SG, but I do I have an Ultragauge and I monitor the following:
    Screen 1
    Instant MPG
    Trip MPG
    Coolant temp
    Intake air temp
    RPMs
    Engine Load
    Screen 2
    Throttle Position
    Fuel Consumption (gal/hr)
    MAF Sensor 1
    MAF Sensor 2
  3. Dec 26, 2010 at 9:43 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    ya right now i monitor my trans temp, instant mpg, rpms, intake temp, and water coolant temp
  4. Dec 26, 2010 at 9:49 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    IIRC there are about 6 or 7 sets of codes that will actually do something in 1st gens. Sounds like you have a couple of them already.
    I have a list at work of the Xguage codes I put in my SGII. I'll see if I can find them tomorrow and post them for ya.
  5. Dec 26, 2010 at 9:53 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    thanks
  6. Dec 27, 2010 at 8:11 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Here are all the Scangauge programmable codes (x-gauge) that work on my truck.
    MAF (Mass Air Flow)
    TXD: 07 E0 01 10
    RXF: 04 41 45 10 00 00
    RXD: 28 10
    MTH: 00 01 00 01 00 00
    Trans Temp
    TXD: 68 6A F1 01 B4
    RXF: 04 41 05 B4 00 00
    RXD: 28 08
    MTH: 00 09 00 05 FF D8
    Horsepower
    TXD: 00
    RXF: 40 00 80 00 00 00
    RXD: 00 00
    MTH: 00 0A 00 17 00 00
    Here are some more that I tried but could not get to work on my truck though my buddy on his '07 Tundra got a couple of these to work.
    From ih8mud.com:
    Altitude Gauge (Feet)
    TXD: 07E02133
    RXF: 04610533
    RXD: 2808
    MTH: FEEE00016B08
    NAM: Alt
    Air to Fuel Ratio (Lambda)
    TXD: 07E02144
    RXF: 04614544
    RXD: 2808
    MTH: 006400800000
    NAM: AFL
    Air to Fuel Ratio (True Air to Fuel ratio)
    TXD: 07E02144
    RXF: 04614544
    RXD: 2808
    MTH: 05BE00800000
    NAM: A/F
    Atmospheric Pressure (PSI)
    TXD: 07E02133
    RXF: 04610533
    RXD: 2808
    MTH: 000A00450000
    NAM: PSI
  7. Dec 27, 2010 at 10:39 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    thanks. ive got the tranny temp and hpr. what does the mass air flow measure? and ive tried the altitude and it doesnt work on my first gen either
  8. Dec 28, 2010 at 7:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It would have been very cool if the altitude one were to work. It woulda helped to settle a lot of arguments. :D
    Now I'm not sure on the MAF one. I think its purpose would be to give a baseline on the performance of the sensor.
    I thought I had entered the MAF codes and had a result but I was scrolling through all the readouts today on the way home and didn't find it under that name. When I get a chance I'll review all the xgauge entries I've done to see if I might have used a different name.
  9. Dec 28, 2010 at 8:06 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    okay. ya i need to erase the altitude one that i plugged in. definately woulda been nice for that to work
  10. Dec 30, 2010 at 12:21 AM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    what rate on you running your scangauge on? it says not to run ISO's on fast but thats what i have mine on and it doesnt seem to have a problem
  11. Feb 3, 2011 at 2:32 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Does trans temp work on first gens? Didnt work on mine..
  12. Feb 3, 2011 at 2:41 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    yup. works only on first gens. ive heard toyota wont give them the codes to get it to work on 2nd gens
  13. Feb 3, 2011 at 2:42 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Hmm. I guess Ill keep trying and if it doesnt work then maybe retrying the code? Idk..
  14. Feb 3, 2011 at 2:45 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    just double check and make sure that you input the code correctly cus one little thing off and the entire code is f'ed
  15. Feb 3, 2011 at 2:47 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    does it not work on manual trannys?
  16. Feb 3, 2011 at 2:47 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    It doesnt work on manuals?
  17. Feb 3, 2011 at 2:51 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    o. cus i know a manual tranny doesnt get as hot but i figured they would still install a temp sensor
  18. Feb 3, 2011 at 2:52 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    True. I figured it would still have one though. Thanks!
