Sh*t
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dryheat, Jun 23, 2024.
  1. Jun 23, 2024 at 10:12 AM
    Clearwater Bill
    Billy
    Largo Florida
    This ^^^^
    Uber, walk, bike, hitch, but do NOT drive the truck. You now have both a transmission AND and engine issue.
    You just doubled down on your freak out mode.
    I'd just dump the engine oil and start over there while you're at it.
    Expensive and time consuming lesson, but one you won't forget!
    Chew, Taco22trdor, Junkhead and 9 others like this.
  2. Jun 23, 2024 at 10:27 AM
    dryheat
    dryheat [OP] Well-Known Member
    That's exactly what I'm doing. I'm going to dump all the oil replace it with fresh stuff and add a few quarts of transmission fluid until I can get it to the mechanic tomorrow. Expensive mistake.
  3. Jun 23, 2024 at 10:41 AM
    2023tacomer
    2023tacomer Well-Known Member
    Ouch. Good thing you figured it out before you ruined the transmission. And engine, you've got 12 quarts in it. Start all over but no reason to touch the oil filter.
    Not being a jerk, but if you were measuring and looking at the fluid, didn't it look a bit red?
    Best way to solve this from happening again is get a manual transmission, ha. Hope all goes well rectifying.
  4. Jun 23, 2024 at 1:03 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
  5. Jun 23, 2024 at 1:15 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    PSA. For all the guys who’ve done this, take a paint pen and mark the pan with an E and a T by the drain plugs. OP you’re not the first and definitely won’t be the last.
  6. Jun 23, 2024 at 1:23 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    One other tip for checking the notoriously-bad dipsticks on some Toyota engines --
    Let the truck sit overnight or at least 12-14 hours. This gives oil in the dipstick tube, on the dipstick itself, and up in the engine the time to fully drain down.
    Pull the stick in one smooth, continous, but not fast movement after the truck has sat 12-14+ hours, and usually there is a very clear, easy-to-read oil level on at least one side of the stick.
    It's only that first pull after sitting 12-14 hours that usually comes out clean, don't bother trying to wipe the stick, reinsert and check again. Subsequent checks are usually smeared and ambiguous.
  7. Jun 23, 2024 at 1:30 PM
    gotoman1969
    Food for thought. I’ve had 5 Toyota trucks for a total of almost 3 million driven miles. Currently a 2015 w/150k and literally have never pulled a dipstick between oil changes.
  8. Jun 23, 2024 at 1:42 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    That’s crazy!
  9. Jun 23, 2024 at 1:46 PM
    GilbertOz
    GilbertOz Driver
    CA
    Seems like that's tempting fate.
    My 2014 V6 w/ 80K miles burns zero oil but I check the dipstick weekly at least, just because I like seeing the oil level not change.
  10. Jun 23, 2024 at 1:47 PM
    gotoman1969
    They have therapist for this, :eek::rofl:.
  11. Jun 23, 2024 at 1:58 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    you might read a manual before working on you vehicle
  12. Jun 23, 2024 at 4:46 PM
    dryheat
    Thanks
    RIX TUX[QUOTED] likes this.
  13. Jun 23, 2024 at 5:34 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    You may want to change your thread title to "Oopsie" or something...
  14. Jun 23, 2024 at 7:35 PM
    oldtimertoyota
    New Mexico
    The titles fine, many have made the same mistake. OP use this as a learning experience and move on.
    soundman98 likes this.
  15. Jun 23, 2024 at 7:45 PM
    #35
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    This. Best way to read it.
    AlBrewer[QUOTED] likes this.
  16. Jun 24, 2024 at 5:04 AM
    #36
    dryheat
    Done.
    RustyGreen and oconnor[QUOTED] like this.
  17. Jun 24, 2024 at 5:07 AM
    #37
    dryheat
    Update: The dealership parts was closed so I went to an auto parts store, picked up some tranny fluid. Got back home and realized I don't have a 24mm socket. Ran back up and bought one. Got back and realized my 1/2 socket is way to big to fit up in there. I said screw it, drained the engine oil (it was a LOT lol), replaced the oil, and scheduled a free tow truck for the morning to a nearby Toyota mechanic.
    oconnor, BabyBilly and Boerseun like this.
  18. Jun 24, 2024 at 6:24 AM
    #38
    WesNeedsCoffee
    WesNeedsCoffee Well-Known Member
    Wes
    2021 Tacoma OR DCSB MT
    You might want to disconnect the battery so the tow truck driver and/or lot jockey at the shop doesn't try to drive the truck -- should slow them down enough to maybe realize there's no ATF in the transmission.
    Big tall dave likes this.
  19. Jun 24, 2024 at 6:27 AM
    #39
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Better to pull the fuel pump control module fuse so they can at least get it in neutral without the manual bypass.
  20. Jun 24, 2024 at 6:36 AM
    #40
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Same. If there's no obvious leaks and no smoke from the exhaust, the oil is still in there.
