shackle bolt size?
Discussion in 'Suspension' started by brelandt, Nov 19, 2010.
  1. Nov 19, 2010 at 4:42 PM
    brelandt
    brelandt [OP] Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    Search turned up nothing on this so I'm going to ask. What size are the shackle bolts on the 1st gen trucks? I bought a 1.25 shackle kit with grease able bolts and bushings but I can not get the old bushings out of the leaf spring. So I'll just buy new stock size bolts and just not use the new bushings.
  2. Nov 20, 2010 at 8:38 AM
    brelandt
    Terry
    Dublin, CA
    I suppose nobody knows? I'll just figure it out then post my findings so that in the future others will know.
  3. Nov 20, 2010 at 8:41 AM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
  4. Nov 20, 2010 at 4:24 PM
    brelandt
    Terry
    Dublin, CA
    the stock shackles bolts are both pressed in. I can not reuse them on my new shackle kit. therefore I need to run out and get a new bolt the same size as the stocker cause it has to fit inside of the metal sleeve of the leafspring bushing.
    Anyhow, just went to the hardware store and brought the nut and the new lift shackle with my and got a bolt and nut that works.
