Shackle Flip Kit - The Official Armor Tech Offroad Thread!
Discussion in 'Armor Tech Offroad' started by ArmorTech, Mar 6, 2013.
  1. Sep 27, 2013 at 2:08 PM
    #201
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    He sent this to me about 2 months ago....I think it was an attempt to see what the mounting locations for the all pro should be so he can mass produce. I just haven't had really any time to install them :pout:
  2. Sep 29, 2013 at 8:09 AM
    #202
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    all done....had to cut 2" off of them
  3. Sep 29, 2013 at 9:37 AM
    #203
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Hey Adam, I'll be running stock springs for the forseeable future. Are these adjustable one's for non stock spring applications?
    I'm planning on Wheelers 3 leaf HD AAL set up, Billstein B110's, Firestone bags, your flip kit and a bunch of meassuring to mod the bump stops. I carry a bunch of weight in tools, 4-500 lbs, so I'm unsure of lift higth and shock lenghts.
    Any thoughts, comments, anyone?
  4. Sep 29, 2013 at 1:47 PM
    #204
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    Why did you have to trim them?
    All seems good, just don't forget the extended brake lines :thumbsup:
  5. Sep 29, 2013 at 2:02 PM
    #205
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    I had to trim because I had an adjustable set that had a ton of adjustments and it wouldn't fit with my rear bumper mounts...
  6. Sep 29, 2013 at 2:04 PM
    #206
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    35 below the door :D
    DoulosXP likes this.
  7. Sep 29, 2013 at 3:12 PM
    #207
    Gearheadesw
    Davenport Fl
    All seems good, just don't forget the extended brake lines :thumbsup:[/QUOTE]
    Thanks mjm540ii, that's one thing I was forgetting, excellent
  8. Sep 29, 2013 at 5:52 PM
    #208
    ArmorTech
    ArmorTech [OP] Well-Known Member
    Adam
    Slimwood, sorry you have to trim your brackets. I wish you would have called me before going to all the trouble. You'll have a new set coming to you when we get back from Expo just because I'm not sure how much I trust having those slots open on the back side.
    Because someone (I'm not naming any names) goofed up and test fit the first round of adjustable mounts with no rear bumper on the truck. Therefore easily overlooking the fact that the rear bumper mounts are right there unless you're running a shorter spring. That whole batch went in the scrap bin, but unfortunately not before Slimwood's shipped. We're now doing all shackle flips like SoCalTaco's. The new brackets have a good amount of adjust ability that will work with most, if not all, spring combinations. This includes stock, OME Dakars, AP standard and AP Expo.
    I was trying to go with keeping all of the holes in the main bracket because I don't like the extra holes in the shackle tabs. In the end we threw both brackets in our test fixture and put WAY more force on them then you'll ever want the back of your truck to see and had no issues. Well other than nearly ripping 2 half inch bolts through a piece of 3x3x3/16 square tube...
    The new universal shackle flips are setup to run stock, OME Dakars, AP standard and AP Expo and any other spring that will work with the factory shackle mount. Beyond that I can't comment on shock lengths as I don't have those springs to test out myself. You'll want to cycle the suspension without shocks to measure what length you need before wheeling the truck.
  9. Sep 29, 2013 at 5:58 PM
    #209
    mjm540ii
    Oxford, PA
    Damn, I wish I wasn't so quick to order from the first batch in april:(
  10. Sep 29, 2013 at 6:00 PM
    #210
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Sweet:thumbsup:
  11. Sep 30, 2013 at 8:26 AM
    #211
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    were you on the bump? How bad was the negative arc if it was?
  12. Sep 30, 2013 at 8:36 AM
    #212
    TRDtexasTaco
    TRDtexasTaco Well-Known Member
    JP
    Sunnyvale Trailer Park
    06 TRD PreRunner
    Billy shocks, Maxtrac spindels, AllPro standard leafs, BAMF shock relocation, King 2.5 smoothies
    anything for the all pro standards?
  13. Sep 30, 2013 at 8:41 AM
    #213
    SoCaltaco65
    the standard and expo are about the same spring, expo leafs a bit thicker to add the 20% higher spring rate, eye-eye are the same.
  14. Sep 30, 2013 at 8:52 AM
    #214
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Yeah I was...the arch wasn't too bad. Next time I will take better pictures...
  15. Sep 30, 2013 at 8:57 AM
    #215
    SoCaltaco65
    great, most likely the same im getting, Im seeing 2-2.5 degrees without adjusting the bumps, hydros are about to go on and will adjust to have 1.5
  16. Sep 30, 2013 at 9:02 AM
    #216
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    negative arch ftw :rolleyes:
  17. Sep 30, 2013 at 9:11 AM
    #217
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    :eek:
  18. Sep 30, 2013 at 9:21 AM
    #218
    SoCaltaco65
    holy premature flattening bat man! :eek:
  19. Sep 30, 2013 at 9:42 AM
    #219
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    nah, the springs were already shot, so i figured i might as well get all i can get from them and mountede some shorter bumps. got a new system in the works, just waiting for time and a driveway to do the work. great for crawling though.
  20. Oct 4, 2013 at 6:39 AM
    #220
    ArmorTech
    Adam
    The new kit is universal, no need for a separate kit for any certain spring.
    Looks like a factory spring would. But you need some better bump stops.
