Shackle Flip Kit - The Official Armor Tech Offroad Thread!
Discussion in 'Armor Tech Offroad' started by ArmorTech, Mar 6, 2013.
  1. Feb 26, 2014 at 2:04 PM
    #341
    BradyT88
    BradyT88 Well-Known Member
    Yep and realistically if you just get a set of Allpro Expos with the shackle flip it can still handle a good amount of weight since the Expos already have such a high spring rate.
  2. Feb 26, 2014 at 2:06 PM
    #342
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    yea ive seen those handle a lot, seems like it would be a good combination for lift also.
  3. Feb 28, 2014 at 5:01 PM
    #343
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    What shock relocation kit are you using?
    I will soon have a very similar setup. With the XJ shackles, all pro expos and Pelfreybilt shock relocation kits.
    All I need is the shackle flip kit but I can't order it on the ATO website due to addressing issues.
    ADAM! Help! Lol
  4. Mar 12, 2014 at 12:36 AM
    #344
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I have had the flip kit since October, and now I have finally completed it. One hell of a time.
    I tried a few different methods, and this seemed to be the quickest and easiest
    I used an air cut off tool, went through 3 wheels, and a 1/2" drill bit. Once the rivets were cut off, all I had to do was get the bit started on slow speed, then go to high speed to finish up. Once the bit drilled through far enough, the rivets just popped the rest of the way out.
    Same with the AP standard leafs, I also had to trim a little bit of material off of my tow hitch bracket in order to get the flip to the furthest setting
    Checked out Zone off road, they have these and a set of greasable shackles, pretty nice.
  5. Mar 12, 2014 at 9:09 AM
    #345
    BradyT88
    When we did mine, we used a 14" grinding wheel to grind the heads off all the rivets, then pried the hangers off and ground the rivets flush to the frame again. Then drilled them just a little with like a 1/4" bit and hit them with an air hammer. That made short work of them. The front hangers are a lot harder to remove than the rear ones.
  6. Mar 12, 2014 at 10:09 PM
    #346
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    when i did mine i ground the heads off the rivets, then heated the area around the rivets and hammered them out with a 3 pound mini sledge. took no more then 4 hits on each rivet.
  7. Mar 13, 2014 at 8:12 AM
    #347
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    When I did mine ....... Oh wait ...... I haven't done it yet. Nevermind :cool:
  8. Mar 13, 2014 at 8:21 AM
    #348
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    I have a bedcage and 14" bypasses
  9. Mar 13, 2014 at 10:27 AM
    #349
    WV coal miner
    WV coal miner Member
    Bluefield WV
    2013 regular cab 4x4 magnetic grey
    20% tint, in channel vent visors, mud flap delete, rear diff breather mod, afe pro dry s air filter, weather tech floor liners, custom center console, cb radio, 285/70r17 DuraTracs on fuel trophy wheels, 3 inch OME lift with Dakar leaf pack, Light Racing UCAs, Avid off-road rock sliders.
    can anyone tell me what shocks they used to get the full potential out of the flip kit with a Dakar leaf pack??? I'm trying to gather up all the parts to do mine and this seems to be the hardest to figure out. I currently have OME shocks but want the most out of my kit. just curious what others used with their Dakar leafs.
  10. Mar 13, 2014 at 11:25 AM
    #350
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Kings make a good one but i think ur limiteb by the stock shock mount
  11. Mar 14, 2014 at 8:55 AM
    #351
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I hauled just shy of a ton of gravel in the bed of my truck the other day and it handled great. I have expos, shackle flip, bilstein b110 shocks and hockey puck/timbren bump stops. Bumps were slightly compressed but the truck drove great.
    Bilstein b110 shocks (around $150 I think from wheelersoffroad.com) they are designed for more lift than the normal 5100s. Just need to make sure the compressed length will work. I had to add a hockey puck to my bump stop so the shocks can't bottom out. So realistically I lost a small amount of up travel but I gained a lot of down travel.
  12. Mar 14, 2014 at 10:24 AM
    #352
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    I would like to get rid of the blocks under my saggy springs, but maintain, or raise the level slightly. I am thinking of a Shackle flip and 2" add a leaf. Can someone give me a little guidance? I do pull a trailer every now and then, and I've seen where the shackle flip is not ideal for this. Would i be better off getting a new leaf pack?
  13. Mar 14, 2014 at 10:45 AM
    #353
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    If you leafs are sagging now your going to blow through that add a leaf in a matter of months. 2 inch lift springs and a shackle flip nets 2.5 to 2.75 inches of lift normally. I have dakars and the first gen ato flip and it gave me about 3 full inches, I tow a 3500lbs trailer with no problems and Im long travel up front as well.
  14. Mar 14, 2014 at 10:50 AM
    #354
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Does the shackle flip take some of the hardness out of the Dakars? I've heard they have somewhat of a harsh ride. (yes i know it is a pickup truck, not a lincon). The jeep I have will knock your fillings out, I don't want to have another ride like that.
  15. Mar 14, 2014 at 11:34 AM
    #355
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Yes it does.
  16. Mar 14, 2014 at 2:26 PM
    #356
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Ok. So for choice of shocks, 5100's, nitro's,?? What about brake lines? Extended?
  17. Mar 14, 2014 at 2:31 PM
    #357
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Extended brake lines for sure. For shocks you need to measure compressed and extended lengths from mount to mount and buy according to that.
  18. Mar 14, 2014 at 4:55 PM
    #358
    JLink
    Josh
    Ocean, NJ
    what?
    this^
    typically the bilstein b110's (5100s for more lift) are the right length and affordable.
  19. Mar 14, 2014 at 5:42 PM
    #359
    BradyT88
    OME Nitrochargers I'd guess.
  20. Mar 24, 2014 at 7:53 PM
    #360
    dcvt16
    dcvt16 Well-Known Member
    Ehren
    SCV, CA
    SOLD =( MGM Supercharged long travel 5lug
    Total Chaos 5 lug long travel kit, Fox coilovers. Mcneil fiberglass. Defined engineering sua, 14 in kings, Defined shock hoops rear. Weathertech digital liners and vent visors. Paint match grille and added fogs. 4.56 gears, detriot truetrac LSD (gear type), LCE header, URD 2TR supercharger.
    Anyone know where Adam went? Hasn't been on here for a while, no email response either.
