Shackle Flip Kit - The Official Armor Tech Offroad Thread!
Discussion in 'Armor Tech Offroad' started by ArmorTech, Mar 6, 2013.
  1. Mar 24, 2014 at 8:02 PM
    #361
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Typical! Wait till you have a problem with a product as well... Customer service gets worse then.
  2. Mar 25, 2014 at 9:21 AM
    #362
    ArmorTech
    ArmorTech [OP] Well-Known Member
    Adam
    Sorry we've been slammed, I've not had much time lately to get to emails, and no time to get to the forums. Things are getting better now with a new employee that is doing great. What's up?
    Couldn't be farther from the truth if you'd bother to pick up the phone or actually work WITH us! But you'd rather just belittle us on the forums. If you'd like to knock that crap off and call me I'd be happy to talk with you
  3. Mar 25, 2014 at 10:58 AM
    #363
    dcvt16
    dcvt16 Well-Known Member
    Ehren
    SCV, CA
    SOLD =( MGM Supercharged long travel 5lug
    Total Chaos 5 lug long travel kit, Fox coilovers. Mcneil fiberglass. Defined engineering sua, 14 in kings, Defined shock hoops rear. Weathertech digital liners and vent visors. Paint match grille and added fogs. 4.56 gears, detriot truetrac LSD (gear type), LCE header, URD 2TR supercharger.
    I pm'd you while back, I'll send another.
  4. Mar 25, 2014 at 11:15 AM
    #364
    ArmorTech
    Adam
    got you covered Ehren.
  5. Mar 25, 2014 at 11:22 AM
    #365
    dcvt16
    Ehren
    SCV, CA
    :thumbsup:
  6. Apr 8, 2014 at 8:13 PM
    #366
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    Anyone install this with a Dakar pack? looking for which holes were used.
  7. Apr 24, 2014 at 10:49 AM
    #367
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Thanks Adam they look good.
    I have the XJ shackles I will be using and they are not a snug fit at all. What should I use for a "spacer" to fix the gap? Anyone deal with this?
  8. Apr 24, 2014 at 10:58 AM
    #368
    ArmorTech
    Adam
    Our Shackle Flip kit is designed to work with the factory shackle. The Jeep shackle is narrower than the one Toyota uses. I personally have not fit up a set of the XJ shackles, how much gap is there?
  9. Apr 24, 2014 at 11:17 AM
    #369
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    you either use a few fender washers or have/make a delrin bushing set made like I did, its 1/4 inch total or 1/8 either side, don't try to pinch together.
    New beefer shackles going on this weekend
  10. May 10, 2014 at 12:54 AM
    #370
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    ^:drool::drool:^
    I received my ATO shackle Flip kit today, thanks Adam, now i'm just waiting on all the rest.
    Super psyched to get all my stuff together for a whole new suspension, can't wait to start wrenching (and probably some cussing involved......and beer).
    Should I powder coat, paint, put some kind of coating on my brackets for the flip kit?
  11. May 10, 2014 at 11:18 AM
    #371
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    just rattle can them. everything on the truck should be touched up with spray paint every so often as you see stuff starting to rust.
    to save some cussing spray nuts and bolts that have to come apart, with pb blaster days before you're going to work on it so they come apart easier.
  12. May 10, 2014 at 4:30 PM
    #372
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Yeah, I some stuff that works wonders for that. It is a penetrating oil called Airokroil, i think that is how it's spelled, I had planned on it anyway.
  13. May 10, 2014 at 4:32 PM
    #373
    PPansini10
    PPansini10 Well-Known Member
    Paul
    NJ
    09' DCSB 4x4 TRD Sport
    Does anyone know if the OME nitrocharger 9000 rear shocks would work with the flip kit?
  14. May 10, 2014 at 5:51 PM
    #374
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    We are about to find out. This is the only thing i'm worried about, but if it comes down to it, I could probably remove a leaf, or just get extended shocks.
  15. May 10, 2014 at 6:52 PM
    #375
    JLink
    Josh
    Ocean, NJ
    Probably not, if you check the extended and collapsed length you'll know for sure. For reference the bilstein b110 shocks are the correct extended length but the collapsed length is too long so I'm using hockey pucks as bump stop extensions.
    B110s are cheap enough. And removing a leaf wouldn't help you. You're still going to have too much droop for the shocks.
  16. May 10, 2014 at 7:03 PM
    #376
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    I should be fine for normal day to day driving for now though correct?
    Most of the offroad driving I do is logging roads, or dirt roads down to the rivers. Not really much need for flexing the suspension out.
  17. May 10, 2014 at 7:25 PM
    #377
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    If you don't need the flex, why go through all the work to do the flip kit?
    That's the whole point of it anyway...
  18. May 10, 2014 at 7:26 PM
    #378
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Ain't pretty, but it works. :D
  19. May 10, 2014 at 7:37 PM
    #379
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Future. I figured if I am going to tear it all apart to put the leafs in, I might as well go ahead and change it all out at once.
  20. May 10, 2014 at 7:39 PM
    #380
    Yaozer
    Yaozer Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
    Subbed w interest.
