Shackle Flip Kit - The Official Armor Tech Offroad Thread!
Discussion in 'Armor Tech Offroad' started by ArmorTech, Mar 6, 2013.
  1. Jan 10, 2015 at 8:43 AM
    #421
    Softtacosupreme
    Softtacosupreme Well-Known Member
    Hey guys. I've looked through this entire thread and didn't see this. Well as far as the shocks. I'm running the standard allpro leafs. Which this fits. But I have 10" fox 2.5's. 28.4 extended and 18.5 compressed. I'll be running 2.0x3 fox air bumps and I think I'll be doing some limit straps, depends. Would this suffice? Thanks.
  2. Jan 12, 2015 at 9:49 AM
    #422
    ragincajun35
    ragincajun35 Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
    Sounds like it should definitely work. Especially if you are using limiting straps and bump stops. Just make sure that you are within range of your shocks. Test it out. I tested mine at a loading area behind a grocery store before i took it off road and wheeled it
  3. Jan 12, 2015 at 10:17 AM
    #423
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    Do the shackle flip then flex it out, measure and check. Only way to be sure.
  4. Jan 13, 2015 at 8:03 AM
    #424
    Softtacosupreme
    Thanks! Good idea.
  5. Jan 14, 2015 at 8:57 AM
    #425
    ArmorTech
    ArmorTech [OP] Well-Known Member
    Adam
    We've been working on shock data to go with the shackle flips lately and I finally have some info about this. I don't have any all pro springs but I have info that you can use to hopefully compare.
    Stock Springs
    The FULL unbumped travel of the spring, all the way to the over loads when compressed you should see something like the following travel numbers.
    Amount of compression travel - 3.75 inches
    Amount of extension travel - 5.25 inches
    Shock mounting length between stock mounts compressed - 16.25 inches
    Shock mounting length between stock mounts extended - 25.25 inches
    This compression is too far and seriously negatively archs the spring, I'd recommend taking at least 1 inch of compression out with the bumpers.
    OME Dakars
    These numbers are for the full intended travel of the OME springs, which includes negative arch. People who will not accept that OME springs are designed to safely achieve negative arch will not see these compression numbers. We are NOT going to debate the intended travel of these springs, that is a conversation that we have had with ARB/OME. You are welcome to do the same.
    Amount of compression travel - 3.25 inches
    Amount of extension travel - 5.75 inches
    Shock mounting length between stock mounts compressed - 19.08 inches
    Shock mounting length between stock mounts extended - 28.08 inches
    Softtaco, if your travel numbers are anything like the OME springs it looks like you'll be fine. You'll need to adjust the bump stops to take out a bit of compression, and I'd probably still run limit straps just in case. They are cheaper than a new pair of shocks! Our new kit will most likely include limit straps on a 12 inch shock.
  6. Jan 14, 2015 at 12:42 PM
    #426
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Adam do you guys plan on releasing some upgraded shackles?
  7. Jan 14, 2015 at 12:49 PM
    #427
    Softtacosupreme
    Hey thanks so much for the information! This helps. Looks like I'll be picking a set of these up! Thanks Adam!
  8. Jan 14, 2015 at 1:41 PM
    #428
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm looking into this as well, as I am running 25.19 extended and 15.19 collapsed Fox 10" shocks with 2.25" lift. I'm wondering if this'll work for mine as well? I'm a little too lazy to do the math right now. Haha.
  9. Jan 14, 2015 at 1:42 PM
    #429
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Flex the truck out with no shocks in the back and measure. Will tell you everything you need to know.
  10. Jan 14, 2015 at 2:31 PM
    #430
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Too much work. Lol. It was a total bitch to put them on, on the lower mounts, and I really don't feel like unbolting the air bumps, then unbolting the shocks from the lower mount just to make a few measurements. Otherwise I'd be game. The only time those rears will ever come off again is either for a 12" stroke upgrade or when they need to be rebuilt and are leaking out fluid. Haha. :)
  11. Jan 14, 2015 at 6:08 PM
    #431
    Softtacosupreme
    HAHAHAH!! I hear ya!
  12. Jan 14, 2015 at 6:13 PM
    #432
    ArmorTech
    Adam
    By those numbers, it sounds like your shocks are for stock springs, not lifted springs. Currently with 2 inch lift springs and stock shackle mounts, you're shocks are almost certainly the thing limiting your down travel. I would say you need to install new shocks or limit straps or you run the very real risk of blowing out the shocks. Adding a shackle flip will add to the extended length.
    Yep, and add 2 inches to the extended length for the travel gained with the shackle flips.
  13. Jan 14, 2015 at 6:58 PM
    #433
    ArmorTech
    Adam
    Stay tuned radio ranger. :gossip: It's possible that we're just waiting on stuff from laser...
  14. Jan 15, 2015 at 8:21 AM
    #434
    Softtacosupreme
    Hmmmmm. Maybe I'll wait a little longer than.....
  15. Jan 15, 2015 at 11:18 AM
    #435
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    This makes me happy in pants :bananadance:
  16. Jan 15, 2015 at 11:22 AM
    #436
    ArmorTech
    Adam
    Are you guys looking for stock length or something to help lift?
  17. Jan 15, 2015 at 12:19 PM
    #437
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    I am personally not really looking for any more lift. More looking for higher quality, greasable, and possibly have a creeper joint.
  18. Jan 15, 2015 at 1:17 PM
    #438
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's actually the leafs that are limiting the down travel.
  19. Jan 17, 2015 at 8:44 PM
    #439
    Softtacosupreme
    Pretty much this.
  20. Jan 20, 2015 at 6:44 AM
    #440
    ArmorTech
    Adam
    :smash:You used quality and a creeper brand part in the same sentence? We can help with the quality, but it won't involve that brand! Something more like QA1, a joint that will last. But there's bigger problems....
    I doubt we'll be doing any shackles with the flex joints in them. The spacing just doesn't work. They are bigger around than the factory bushing, requiring a different shackle flip. The bodies are also very narrow, creating a problem for keeping stresses down and the ability to fully weld the bracket to the joint. I've looked at it 6 ways from Sunday and it just isn't working out.
