Shackle Flip Kit - The Official Armor Tech Offroad Thread!
Discussion in 'Armor Tech Offroad' started by ArmorTech, Mar 6, 2013.
  1. Mar 16, 2013 at 7:51 PM
    #41
    jberry813
    jberry813 The Mad Scientist
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    You're not really going to be able to cycle the expos more than 11" without going wicked negative arch, which you can easily do with a 10" stroke shock.
    And no matter what, you're not going to get the same amount of uptravel, let alone more uptravel with a shackle flip unless you've got some mad sting bug ride height.
  2. Mar 16, 2013 at 8:04 PM
    #42
    HomerTaco
    HomerTaco Grill Sergeant Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    I've got the original ATO version of this kit.
    Standard stock 3leaf pack with a wheelers progressive 3leaf AAL
    RCD 5100's
    I like it :thumbsup:
  3. Mar 16, 2013 at 8:24 PM
    #43
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    sold everything
    My rear set up is a single aal, and OME shocks. Would I need new shocks to run this?
  4. Mar 16, 2013 at 8:26 PM
    #44
    HomerTaco
    Craig
    Bucks County Pa.
    To take full advantage of the flip kit you would want to. The stock shocks will limit the downtravel.
  5. Mar 16, 2013 at 8:32 PM
    #45
    skidooman
    TJ
    Northern Nevada
    sold everything
    Ok, another question, would these affect towing at all? I don't haul much. Heaviest is a little flatbed with my rhino on it, probably 2k#.
  6. Mar 16, 2013 at 8:34 PM
    #46
    HomerTaco
    Craig
    Bucks County Pa.
    I tow a trailer w/ 2 ATV's with no issues... :notsure:
  7. Mar 16, 2013 at 8:37 PM
    #47
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    OME not OEM :)
  8. Mar 16, 2013 at 8:45 PM
    #48
    HomerTaco
    Craig
    Bucks County Pa.
    Are OME aftermarket shocks longer than OEM?
    The RCD billies have 11" of travel. I'm not sure what OME ones are...
  9. Mar 16, 2013 at 8:47 PM
    #49
    OZ-T
    Peter North
    British Columbia
    IDK , you said stock shocks I thought you mixed up , but I think there's a thread here with shock lengths , I'll see if I can find it
  10. Mar 16, 2013 at 8:51 PM
    #50
    OZ-T
    Peter North
    British Columbia
  11. Mar 16, 2013 at 8:52 PM
    #51
    NYCO
    NYCO ┌∩┐(ಠ_ಠ)┌∩┐
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    ome is something like 16/24? I have measurements in my build of the collapse/ext lengths but I'm on my phone.
    I was definitely being limited on my down travel then got some 10" Fox and saw big improvements.
  12. Mar 16, 2013 at 8:54 PM
    #52
    NYCO
    NYCO ┌∩┐(ಠ_ಠ)┌∩┐
    bOb
    Colorado
    dents & scratches
  13. Mar 16, 2013 at 8:55 PM
    #53
    OZ-T
    Peter North
    British Columbia
    Sweet
  14. Mar 16, 2013 at 9:01 PM
    #54
    HomerTaco
    Craig
    Bucks County Pa.
    Thx OZ. ;)
    So the rear OME shocks are slightly less than 24" fully extended.
    The RCD's i have are 27.28" fully extended.
  15. Mar 16, 2013 at 9:01 PM
    #55
    skidooman
    TJ
    Northern Nevada
    sold everything
    Too slow.
  16. Mar 16, 2013 at 9:02 PM
    #56
    OZ-T
    Peter North
    British Columbia
    Big difference alright
  17. Mar 16, 2013 at 9:38 PM
    #57
    dcvt16
    dcvt16 Well-Known Member
    Ehren
    PDX
    MGM Supercharged long travel 5lug
    Total Chaos 5 lug long travel kit, Fox coilovers. Mcneil fiberglass. Defined engineering sua, 14 in kings, Defined shock hoops rear. Weathertech digital liners and vent visors. Paint match grille and added fogs. 4.56 gears, detriot truetrac LSD (gear type), LCE header, URD 2TR supercharger.
    Order placed. Hope these work on the 5 lug. Leafs are same length as 6 lug..
  18. Mar 18, 2013 at 10:11 AM
    #58
    ArmorTech
    ArmorTech [OP] Well-Known Member
    Adam
    Most likely. You will want a 16/27 shock to maximize both the use of the kit and the life of your shocks.
    There should be no difference while towing.
    Thank you for the order!
  19. Mar 18, 2013 at 8:04 PM
    #59
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    For those wondering, to fully maximize axle travel with use of a shackle flip kit, you're gonna need replacement brake lines and I would bet at least a 12" shock. More may be better.
    Obviously, travel characteristics vary a bit depending on your spring pack, rate, and shackle setup. That said, with OME leafs and a (one off custom) ATO kit with a 3" shackle I was pulling ~13" of travel eyelet to eyelet at the stock shock mounts. A 12" shock wouldn't have done the trick. I ended up with some custom fab to stuff a 15" travel Icon shock under each fender. But that involved more rigamarole than most here will want to deal with.
    My recommendation: Get the shackle flip in, get the brake lines extended, then take your shocks off the rear axle, cycle and measure exactly what your shock travel will need to be. Set up bumpstops accordingly, then order shocks. Until then, either leave the shocks off or stay on pavement.
    Life gets a lot easier if you're willing to relocate the shock mounts. But then, it gets pricier as well.
  20. Mar 18, 2013 at 8:09 PM
    #60
    HomerTaco
    Craig
    Bucks County Pa.
    This is exactly how I did it. :thumbsup:
