Shackle Flip Kit - The Official Armor Tech Offroad Thread!
Discussion in 'Armor Tech Offroad' started by ArmorTech, Mar 6, 2013.
  1. Apr 9, 2018 at 12:08 PM
    #641
    pheerles
    pheerles Well-Known Member
    Rosemead, CA
    '15 Access Cab 4x4
    I've got a HC pelfrey bumper waiting to be installed, so hopefully I can get around that (or I'll have to cut into the pelfrey bumper instead)...I'm hoping everything will clear without cuts!
  2. Apr 9, 2018 at 12:11 PM
    #642
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Imnsure it would be minor if anything.
  3. Apr 9, 2018 at 12:13 PM
    #643
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Looks like they mounted it on the wrong side of the vehicle all together.
    ImplicitlyAlberta likes this.
  4. Apr 9, 2018 at 12:18 PM
    #644
    pheerles
    Rosemead, CA
    '15 Access Cab 4x4
    Wow, I didn't even notice that. It looks like the shackle mount would be positioned further back if I installed them in the correct locations, using the existing bolt holes. I haven't looked, but this would mean the leafs are not aligned, yes? Because if they were installed on the correct side, the shackle would then be mounted directly under the frame, whereas currently it's off to the side?
  5. Apr 9, 2018 at 12:22 PM
    #645
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    It would be off to the side regardless. They are def mounted on the wrong side. You should take it back to whomever installed them and have it corrected. When at full droop, the shackles should just be so slightly angled toward the rear, and when resting on flat ground, they should have roughly a 45* angle toward the rear.
    pheerles[QUOTED] likes this.
  6. Apr 9, 2018 at 12:22 PM
    #646
    ImplicitlyAlberta
    David
    edmonton
    Good eye!!!!
    pheerles likes this.
  7. Apr 9, 2018 at 12:25 PM
    #647
    pheerles
    Rosemead, CA
    '15 Access Cab 4x4
    Thanks so much you guys, I'll reinstall this myself. I've had a few issues with them and never went back for a couple years now. Will send an update when I am able to get this done!
  8. Apr 9, 2018 at 12:25 PM
    #648
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I've always wondered when this would happen
  9. Apr 9, 2018 at 12:27 PM
    #649
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    Here’s how mine look
    5 Lug Fury likes this.
  10. Apr 9, 2018 at 12:30 PM
    #650
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Am I missing something here? Yours looks like it's installed the same as the rest in this thread?
  11. Apr 9, 2018 at 12:47 PM
    #651
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Ok, just looked through the entire thread pretty much, you're right, they all look like that.
  12. Apr 9, 2018 at 12:48 PM
    #652
    deeezy
    Dana
    Hawaii
    I thought I was going crazy trying to see what the difference was. haha
  13. Apr 9, 2018 at 12:49 PM
    #653
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Further investigation says yes, mount in those locations. Looks like you may need to trim some material from that bumper mount. That won't effect the strength of it though.
  14. Apr 9, 2018 at 1:34 PM
    #654
    pheerles
    Rosemead, CA
    '15 Access Cab 4x4
    Ok, my PB high clearance bumper should allow it to fit without any cutting. Someone had asked for a full underskirt picture :censored:, here it is: RearTacomaUpskirt.jpg
  15. Apr 9, 2018 at 6:29 PM
    #655
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    I had to remove my pelfrey bumper to get the flip kit in but was able to reinstall the bumper with no cutting. You can see there plenty of room after but couldn't get it installed at first with the bumper in the way.
  16. Apr 9, 2018 at 7:50 PM
    #656
    ImplicitlyAlberta
    David
    edmonton
    Yep had to dig through my build caise its been so long since Ive checked lol.
    It looks like they do just have to be moved back a bit.
  17. Apr 16, 2018 at 12:34 PM
    #657
    pheerles
    Rosemead, CA
    '15 Access Cab 4x4
    Moved the shackles back one hole. Big improvement already, but it was tough getting the spring to flatten out enough to fit the bolt. I can see why the AP Expo spring warranty is voided with the shackle flipped. IMG_5730.jpg
  18. Apr 16, 2018 at 4:49 PM
    #658
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    The spring pack is not a good spring pack to use with a shackle flip. I found that I greatly reduced my load carying capabilities. What I did was I installed some sumo spring bump stops.
    These specific ones. I did a lot of research to come to this set for load capacity, size and fit.
    They add a bit of a progressive spring but are a true bump stop. They compress to factory height and I no longer have any sag on the rear end. The trade off, its a little more firm when daily driving w/ no load. You get used to it and I like them.
    I do have a set of Chevy springs that i may do the Chevy spring one day, that requires relocating the front leaf hanger. We shall see.
  19. Apr 16, 2018 at 4:51 PM
    #659
    pheerles
    Rosemead, CA
    '15 Access Cab 4x4
    I'm already using Timbrens.
  20. Apr 16, 2018 at 4:53 PM
    #660
    WhiteNemesis
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    I too had already upgraded my bump stops, but those AP Expos needed help after doing the shackle flip. That is what I did to bring my load capacity back to what it was before. If you find you have this problem, throwing out the solutions
